Safety is Built In, Not Assumed: Keeping Collision Avoidance Ahead of the Traffic
Combining TCAS and ADS-B In can give pilots more time to prevent midair collisions.
Safety is built in, not assumed: keeping collision avoidance ahead of the traffic
[Credit: Keena ithar | Shutterstock]
  • TCAS (Traffic Collision Avoidance System) is a critical, reactive last line of defense that alerts pilots only *after* a loss of separation has occurred, often under significant time pressure and potential human factor challenges.
  • To improve safety, lawmakers are proposing mandating ADS-B In technology, which provides pilots with proactive, real-time situational awareness of surrounding traffic.
  • Combining reactive TCAS with proactive ADS-B In creates a more robust collision avoidance strategy, giving pilots additional time to manage conflicts, reducing pressure, and enhancing overall airspace safety and efficiency.
This summer, two commercial passenger aircraft came within seconds of colliding over Hartsfield-Jackson Atlanta International Airport before their safety systems intervened. The final line of defense was their traffic collision avoidance systems (TCAS). TCAS is an onboard safety system that alerts pilots to other aircraft in their vicinity. If the system detects a potential flight path conflict, it will issue alerts to the flight crew. These alerts are intended to bring awareness to the other aircraft and, if needed, instruct the crew to avoid the conflict.
Essentially, TCAS is a final line of defense, alerting pilots after loss of separation has occurred; this could be the result of technical errors, controller oversight failures, or limitations in pilots’ situational awareness. The pilot then follows the system’s commands, helping everyone reach their destination safely, as was the case in Atlanta.
Reliant on predictable human behavior
These outcomes rest on the assumption that both the technology and the crew will always perform as expected. With Resolution Advisories (RA), the highest level of alert, there is a potential startle factor, combined with a very brief decision-making window. The crew will want to understand what is going on and may confirm the loss of separation by looking to other sources of information (i.e. looking out the window or at available flight deck displays). Pilots are used to having air traffic control direct them, and they might be awaiting instruction from the tower. These are all factors that may delay responses in situations where there’s very little room for error.
Under the International Civil Aviation Organization standards, a pilot’s response to an RA is expected within five seconds of the alert (and half of that time in the case of a reversal). This puts significant pressure on pilots to perform maneuvers with both speed and accuracy. A study has found that the RA response decision window may be too small for even the best trained crew to always execute commands accurately, with nearly half of pilots responding weakly or incorrectly, not for lack of expertise, but due to understandable human factors. Near misses happen in the US daily, so the importance of having the best available collision avoidance technology in the flight deck is paramount.
Reliable today, better tomorrow
US lawmakers have recognized these pressures and are proposing regulation that would mandate ADS-B In technology in the flight deck. This mandated display of ADS-B traffic information would provide pilots with better situational awareness of surrounding traffic, allowing for a more proactive role in separation management.
ADS-B In is the receiving half of the ADS-B system already fitted to commercial aircraft. It gives pilots a GPS-precise view of surrounding traffic up to 180 nautical miles, updated every second.
Pairing a reactive system like TCAS II with one that offers proactive traffic awareness can earn the crew additional time to react, so conflicts are managed before the last-resort collision avoidance layer is called upon.
The winning combination
The benefits of ADS-B In would go beyond the flight deck. En route, for instance, ADS-B In can help by optimizing spacing through Interval Management. In our trials, ATC spent noticeably less time talking to ADS-B In-equipped aircraft, freeing the controllers to focus on their primary job, maintaining a safe airspace. Quite simply, the technology works with the procedures and the people, not instead of them.
Collision avoidance systems will remain at the heart of aircraft safety. It’s a proven last line of defense. As airspace gets more congested and with the rise of EVTOL craft, pilots, passengers and ATC deserve the benefits of combining both reactive and awareness based technologies to ensure we truly have safer skies.
Cam Morast
Cam Morast is an experienced Product Manager at ACSS with a demonstrated history of working in the commercial aerospace industry, including surveillance product line business development, flight test engineering, systems engineering and avionics certification. ACSS is a joint venture between Acron Aviation and Thales.
  1. Avatar for vince vince says:
    ADS-B is not a collision avoidance system and was not designed as one. It is a traffic advisory system. TCAS is a certified collision avoidance system. The issue is certification and cost. If you want to install a TCAS on your plane, go for it. Top and bottom antennae, certified boxes and transponders, etc. Also, TCAS operates on 1090 Mhz, and having all aircraft interrogating on 1090 Mhz, in addition to many ADS-B transmissions, will overwhelm the frequency. And then there are the UAT ADS-B folks that are on a different frequency.
    This was considered when the FAA was moving towards ADS-B. The FAA’s decision was likely a good one. It allows relatively low-cost ADS-B boxes for traffic advisories for smaller aircraft and requires TCAS for larger passenger aircraft. If you want TCAS for your smaller aircraft, go find a vendor–it is allowed.
    Best
    Vince
  2. Avatar for Jim Jim says:
    Cam, your NGT9000 is a fantastic unit. It lives right below the audio panel in my Deb. While I have ADS-B “in” on my iPad, it’s great to have the traffic display on the NGT9000 always at 2nm.
    However, the NGT9000 is no longer priced appropriately, the requirement to re-purchase enablements when purchased used, and the $5k flat rate repair cost are keeping you from the market that the unit deserves. Now, with the Sky Hound, the market continues to shrink.
    I realize that you guys are looking at the huge ADS-B “IN” opportunity on the airlines right now, but the NGT-9000, if it was priced similarly to the GTX345, would really get a lot more (well-deserved) attention.
