Cessna 172RG Cutlass RG
  • The Cessna Cutlass RG, an intermediate model with a short production run, is now considered a good value on the used market, offering decent cruise speeds (130-135 knots), excellent range, and a useful load of around 1,000 pounds, making it suitable as a complex trainer.
  • It is equipped with a highly reliable Lycoming O-360 engine, which stands in contrast to its notoriously problematic electro-hydraulic landing gear system that requires vigilant maintenance and pre-flight inspection.
  • The aircraft boasts an excellent safety record, with most accidents attributed to pilot error rather than design flaws, and its robust 172-derived fuselage contributes to good crashworthiness, though cabin comfort is noted as limited due to cramped space and noise.
Sort of an intermediate hybrid between the venerable 172 and the inestimable 182RG Skylane, the Cutlass rode a fine line for the five years it was in production. Its ill-defined market niche, coupled with the advent of the general aviation recession, kept the production numbers fairly low. Indeed, only 1,191 were rolled out of the factory doors.
History
The timing of the Cutlass introduction was unfortunate; it hit the market in 1980, generally seen as the year when the GA slump began. Essentially, the Cutlass was a retractable 172 fitted with a carbureted Lycoming O-360 and constant-speed prop (the same basic power package found on the fixed-gear Cardinal, though with a different variant of the engine).
Though it fell into the same basic class as airplanes like the Arrow, the Cutlass suffered from a power deficit (compared to contemporary competitors) that kept it from vying successfully for that market niche. Cessnas real goal, we believe, was to create a trainer that would step pilots up to complex aircraft. In this role, the Cutlass did well, with sales to the big flight schools.
In terms of configuration, the Cutlass is straight 172, with the exception of the electro-hydraulic landing gear. Wisely, Cessna left off the main gear doors that had proven so troublesome in other retractable singles.
By the time the 1980s rolled around, light aircraft manufacturers had essentially stopped trying to freshen their models every year. The first Cutlass is pretty much the same as the last.
The used market
Cutlass prices have, for the most part, seriously lagged behind the rest of the used-aircraft market. A 1980 172RG regained its original value only a few years ago, and still hasnt exceeded it by much: this has not kept up with inflation.
All the same, considering the aircrafts competition, its done reasonably well. Arrayed against it are two Cessna models (the ill-starred Cardinal RG and the beloved 182RG Skylane), as well as Pipers Arrow in its various incarnations.
While its possible to get a cheaper 180-HP single-engine retractable, you also stand to get higher maintenance costs. By the same token, the nearest competitor for the Cutlass-Cessnas own 177RG Cardinal-offers more performance, but costs more to own.
For example, a 1971 Piper Arrow (the last year that a 180-HP model was offered) can go one knot faster, carry almost 100 pounds more payload and costs about $15,000 less to buy than the cheapest Cutlass. However, its engine costs an extra $2,500 to overhaul. And, with only 50 gallons of fuel on board, it cant fly as far. Plus theres the fact that its nine years older than the oldest Cutlass.
At the other end of the spectrum, the Cessna 177RG Cardinal will cruise eight knots faster (and carry 12 pounds more). But it uses a 200-HP engine to do it. It also has reduced range, carrying only 61 gallons of gas. The last Cardinal RGs cost about the same as the earliest Cutlasses.
In a sense, though, the sluggishness in price increases makes the Cutlass one of the best values to be had in the four-place retractable market, assuming age of the airplane is a factor. There are a number of reasons for this statement beyond pure acquisition cost.
Bulletproof engine
While there are some Lycoming engine models that can drive an owner to tears, Cessna fortuitously chose the remarkable Lycoming 0-360-F1A6 for the Cutlass. This engine has earned a reputation for reliability far above that of most engines.
Indeed, our check of FAA service difficulty reports for a representative six-year period disclosed only one troubling trend for this engine-sticking valves. Even this, though, appears to be not too great a threat. Only 10 reports surfaced in our printout, with nine of them stuck exhaust valves. Its worth noting that, in the greater context of Lycomings historic valve-sticking problems in -300-series engines, this many reports constitutes minor trouble.
Beyond this, there was nothing else of note in the records. This bodes well for an owners peace of mind, not to mention his pocketbook.
Other maintenance
Not to let enthusiasm carry too far, there are other items on the Cutlass that will cost an owner money. We found several matters that are almost guaranteed to become a problem for a Cutlass owner.
One is the aircrafts landing gear system. Its worth noting that Cessna never termed any of its retractable landing gear systems Land-O-Matic as it commonly did with fixed-gear models. Indeed, theres nothing O-Matic about this system at all, leading one wag to term it Fail-O-Matic.
Like many of its Cessna single-engine retractable brethren, the Cutlass landing gear system is enough to give an owner fits. If its not one thing (like a dead, burned-out or jammed hydraulic pump-of which we counted 13 reports), its another (like gear leg bumper pads which prevent the gear from locking down-some 21 reports filed).
The gear leg bumper pads (also known as down-stop pads) are critical items. Most reports spoke of a pad coming loose, then jamming between the gear leg and wheel well. This prevented the leg from reaching the locked position, and it collapsed on touchdown. Fortunately, the pads are easily visible on preflight, so a pilot can check them before going.
Cracking and breaking of various gear components was another trouble spot. A prime example used to be the plastic T fitting used to help lock the nose gear down. This item was common to most of the Cessna single-engine retractables, and many a pilot and mechanic watched with bemusement and distress as the nose gear on the parked airplane simply folded up, dumping the bird on its nose.
Cessna eventually came out with a metal replacement part, and reports of this problem have since died away. However, we found three reports in our scan, so its worth checking before buying.
Another trouble spot was highlighted by a Cessna service bulletin. Cracking and breaking main-gear pivots accumulated 10 reports in our survey. Wise buyers will make sure the service bulletin has been complied with before putting any money down.
Yet another problem area was main gear actuator bolts. Some 21 reports indicated loose, backed-out or broken bolts. Again, careful inspection of the landing gear is a must for any prospective buyer.
And of course, like the rest of the Cessna single-engine retractables, the Cutlass is prey to a non-recoverable landing-gear system failure. While a hand pump is provided to manually extend the gear in the event of hydraulic pump failure, neither the mechanical nor the manual system will work if theres no fluid to pump. A ruptured hydraulic line or other system leak means a gear-up landing.
Compounding the problem is the hydraulic pump, which will periodically cycle on and off during flight to maintain system pressure. If there is a leak, the pump will probably be done pumping all the fluid overboard by the time the pilot realizes its been running too long and pulls the breaker.
ADs
There are only a handful of 172RG-specific ADs, and those were one-time fixes that appeared 15 or more years ago. A few recent directives of note have turned up recently, however.
AD 98-2-8 is the newest of these, calling for inspection of the crankshaft inner bore for corrosion. 97-1-13 is a shotgun AD applicable to most Cessnas, mandating replacement of a variety of hoses, and 95-11-8 calls for inspection of the prop blade clamp screws. AD 82-27-2 also addresses the prop.
Load and performance
The Cutlass can certainly earn its keep. With a typical 1,000-pound useful load, decent cruise speeds and good range, it will get you, your passengers and some baggage to most places you want to go.
Most owners report 130- to 135-knot cruise speeds. This puts the Cutlass about even with both the Arrow and the Skylane. However, its worth noting that the lowly Grumman Tiger can produce 140 knots using the same size engine with a fixed-pitch prop and its landing gear hanging in the breeze. And the Skylane, of course, has a much better payload.
Interestingly, cruise speed can vary with CG Like the Skylane RG, the Cutlass gains speed as the CG moves aft (and as weight goes down). This may be due to the position of the open wheel wells (there are no gear door enclosures) on the backside of the tapered fuselage. At gross weights, goes the theory, the aircraft flies at a higher angle of attack, which causes the airflow to be disrupted as it passes over the open wells. At lighter weights and/or more aft CG, angle of attack decreases just enough so that the wells are out of the direct slipstream. Then, the air flows smoothly by them, providing a bonus of up to 10 knots, according to one owner.
The Cutlass other big virtue is range. With 62 gallons of usable fuel, youll probably run out of bladder before you run out of gas. The 180-HP Lycoming sips a miserly 10 GPH at max cruise, giving the Cutlass six hours of endurance. Throttled back to a more moderate power setting, fuel consumption drops to eight GPH, giving the airplane a whopping eight hours or more endurance. Indeed, book figures show a range of 720 NM at 75 percent power and 9,000 feet (including reserves). Throttle back to 55 percent power, and range jumps to 830 NM.
The Cutlass is no slouch when it comes to load hauling, either. Max gross is 2,650 pounds. Cessna actually published a ramp weight for the Cutlass which allowed an extra eight pounds to taxi around with-based on the idea that about 1.3 gallons of gas would be burned before takeoff.
A typical Cutlass with an IFR panel might tip the scales at about 1,650 pounds. This leaves a half ton of useful load-quite good for a mere 180-HP aircraft. Indeed, thats enough to allow two 170-pound men and their 140-pound wives to fly away with full tanks. And theres almost always the option of trading some fuel for passenger and/or baggage weight.
Unlike its stablemates, the Cutlass is rather sensitive to balance-if by sensitive one means its possible to load it out of limits. While the Skylane and Skyhawk are nearly impossible to get too far aft, the Cutlass can be loaded that way.
For example, load your Cutlass with 44 gallons of fuel, four 150-pound passengers and 140 pounds of baggage and the CG will be right on the aft limit. But, toss 200 pounds into the rear baggage area (its weight limit) and another 50 pounds on the rear hat shelf and the back seats must remain empty. Its worth noting that air conditioning was not offered as an option on the Cutlass (as it was on the Skyhawk), and CG problems may have been the reason.
Handling
In keeping with its roots, the Cutlass handles much like the 172. Indeed, few pilots would notice much difference. There are differences, though. The controls are a little bit lighter, and pitch trim authority is increased.
As with later Skyhawk and 152 models, the flaps on the Cutlass are limited to only 30 degrees deflection. Although some might argue that the decreased flap deflection robs the Cutlass of some short-field performance, the airplane can still hold its own when operating out of hot, high strips that frighten away many other retractable-gear airplanes. Then, too, many owners have opted for STOL mods which more than compensate for the missing 10 degrees of flaps.
Ground handling, while pretty straightforward, does require some attention. Sharp turns require very slow speeds and some differential braking. Touchdown on landing should be at or very close to the stall, since wheelbarrowing can be a problem. And crosswind correction is a must at all times. Like most high-wing airplanes, the Cutlass can be blown over if not handled properly in strong winds.
Safety
This brings us to the question: How safe is the Cutlass? In a word: Fairly.
A scan of FAA accident records for a typical six-year period disclosed some 57 accidents. Only 15 of these were fatal. Some trends came as no surprise to those who know the airplane.
For example, the single most-common type of accident involved groundlooping. Nine Cutlass pilots couldnt keep the airplane under control once it landed. Another couldnt keep it under control before he left the ground on takeoff. Again, high wings and relatively narrow gear can make life in a gusty crosswind real interesting, real fast.
Landing-gear troubles racked up another dozen airplanes. However, fully half of those accidents occurred when the pilots either simply forgot to put the wheels down or didnt make sure the wheels were down before landing. Real out-and-out gear malfunctions accounted for only six accidents. Typically, these involved gear collapses after touchdown due to a variety of causes.
Living up to its bullet-proof reputation, the O-360 Lycoming was at the heart of only seven accidents. Two engine failures were blamed on carb ice. We can presumably discount another in which the pilot forgot to tighten down the oil filler cap before takeoff. This leaves only four engine failures stemming from mechanical problems-an enviable record for any engine.
When it came to fatal accidents, the Cutlass RG again proved itself a worthy aircraft. We found only 15 fatal crashes in our FAA printout.
Perhaps the most important aspect of these accidents is that none could be directly blamed on aircraft shortcomings. For example, four stemmed from that perennial pilot killer-flying VFR into IFR conditions. In the same vein, two other fatal crashes were blamed on pilots flying while intoxicated.
But the Cutlass RG is, indeed, a docile flyer. Yet one more fatal accident involved a pilot who died from a massive heart attack in flight. His passenger, who was not a pilot, was able to land the aircraft with the aid of instructions from another pilot. Certainly the Cutlass betrays its 172 roots in this incident.
Improper IFR operations (i.e., descending below DH or MDA on instrument approaches) produced two more fatal accidents. Another two were attributed to botched go-arounds that ended up with the aircraft stalling off the end of the runway.
One fatal crash resulted from an engine failure due to carb ice. Two stemmed from low-flying pilots who hit the ground (or trees) as they flat-hatted.
One final accident could only be described as weird. A Cutlass was involved in a collision on the ramp with an aircraft tug. The tug driver fell off, and the airplane ran him over and killed him.
Thus, the Cutlass RG has developed what is, in our opinion, an excellent safety record. This makes the airplane a fine choice for low-time pilots looking to transition to more complex aircraft, provided they have the financial wherewithal to keep the landing gear system in tip-top shape.
Other safety items
The Cutlass has other features which have a direct impact on safety. Some are minor, others not so.
For example, one safety feature weve always touted is shoulder harnesses. The Cutlass came standard with plain-vanilla shoulder harnesses for the front seats. Inertial-reel units were available as an option, and there was even an option for the rear seats to have harnesses installed. As cheap protection against injury or death, the value of shoulder harnesses cannot be understated.
Contributing to safety also is the aircrafts low stalling speed. In the event of a forced landing, low stall speeds mean less impact energy (provided the airplane is under control at the time of impact).
Overall rugged construction is another aid during accidents. After all, the best restraints in the world wont help if the cabin crushes like an eggshell. Cessna provided the Cutlass with the same well-built fuselage that has helped make the 172 so stellar in the area of crashworthiness.
Yet one more item we like is the two-door configuration (three if you count the baggage door). This gives occupants a much better chance of escaping after a crash. Instead of having to climb over seats to get out a single door, they can egress from either side. An added bonus is the design of Cessnas door handles-theyre pretty straightforward, so even non-pilot types should be able to open them easily in an emergency. (Unlike some Piper doors which have two latches and present the unfamiliar with a Chinese puzzle as they try to get out of the aircraft quickly.)
On the minus side of the safety ledger sheet are the fuel lines that run around and under the cabin. Weve always felt that its best to keep the gas as far away from the people as possible. At the very least, these lines should be of heavy-duty construction, preferably with self-sealing disconnects at the ends.
Another item were not too fond of, safety-wise, is the historic problem of Cessna seats. As with its progenitor, reports of cracking and breaking seat rails in the Cutlass are not unknown. The seat-slip accident has already proven itself fatal on too many occasions, so prudent owners will make a careful check of the seat rails part of their preflight inspection, and making sure the seat is actually locked in place before engine start. Throw in a thorough examination by your A&P at annual inspection time just to be sure.
Comfort
When it comes to comfort, the Cutlass is no bargain. With a cabin width of only 40 inches (only for the front seats), its cozy, to put it mildly (cramped to put it more forcefully).
Rear-seat passengers fare worse. The cabin tapers from the front seats on back, and the roof slopes down. The back seat is no place for big people.
Noise is another problem for the Cutlass. One rather informal survey found the Cutlass and the 172 among the worst of a half-dozen similar aircraft. Unfortunately, a bigger engine did not merit better soundproofing to go with it.
Admittedly related only to aesthetic comfort, some owners complain that the interior of the Cutlass is cheap. Many of the plastic fittings, flashings and trim crack easily and wear over time. In some instances, even the most conscientious, tender loving care wont save these parts.
While the high wing allows a good view of the ground going by, it also limits visibility into turns. And, of course, looking up is almost impossible without badly craning ones neck.
Mods, club
Many owners have opted for STOL mods from groups like Horton. This is perhaps the single most popular mod for the Cutlass RG.
Another reasonably popular improvement involves various speed kits. Flap and aileron seals offer at least a few knots extra cruise. Most companies that make mods for the 172 also make versions for the RG.
We highly recommend that owners and interested parties join The Cessna Pilots Association (www.cessna.org, (805) 922-2580).
Owner comments
I have more than 2,000 hours in four different 1980 Cutlass RGs. Much of my flying has been from a local STOL port at 6,900 feet elevation, and I rarely operate from fields below 4,650 feet, so my comments reflect this.
The 1980 Cutlass RG is unequivocally the best airplane for the dollar that I have ever owned or flown. I fly mainly alone, or with my wife and a weeks worth of baggage, or less. At 12,000 feet with half fuel, 18 in. MAP and 2300 RPM, I cruise at about 120 knots and consume eight gallons per hour of fuel.
The Cutlass is extremely reliable. All of my engines have made it to TBO plus 300 or 400 hours. I use AeroShell oil and change it every 50 hours.
Starting cold or hot is easy and reliable. The landing gear and electrical problems have been minimal, though the gear warning horn is erratic and should never be trusted. I would prefer to have it removed or deactivated, personally.
Like any four-place airplane with 180 HP, you can rarely fill the seats and the tanks at the same time. Mid-summer operations from STOL fields have to be planned for early morning departure with half tanks and light weight. Every flight with three or four adults has to be carefully planned.
Nearly all of the Cutlass RGs have had a gear-up landing. Three of my four airplanes have. The major damage is to the belly skins and antennae, so if the plane has been properly repaired, the prospective buyer has nothing to fear. The aircraft logs should show a new or overhauled prop and an engine teardown. One of my Cutlasses had a gear-up in 1982 just before I purchased it, and I have flown it more than 1,000 hours since then with no problems.
The small wheels make the Cutlass a poor airplane for anything but paved surfaces. Longer than expected grass or softer than expected soil can lead to disaster.
As a transition aircraft for training, the Cutlass is an ideal step in the 152-172-172RG-instrument-commercial sequence. It provides a good platform for instrument training and gives the student complex time at little extra cost over that of a comparably equipped 172.
The cabin is comfortable and well organized. Noise levels are considerably higher than a 172 or a Cardinal, so conversation can be a bit awkward.
The panel has room for all of the avionics that you can afford, or the Cutlass can lift. Trim is the usual tacky Cessna plastic that breaks if a shadow crosses it. The pilots armrest is perennially brokeN.
The Cutlass RG is not an A36 Bonanza or a Mooney 252, but it is a reliable, straightforward, fuel-efficient speedy plane thats fun to fly, great for trips with two adults and holds its value with the best of them.
John D. Burrington
Steamboat Springs, Colo.
We have owned our Cutlass for 18 very pleasant months. Fuel consumption is good, showing about 7.64 gallons per Hobbs hour, or 9.39 gallons per tach hour. Maintenance costs, both scheduled and unscheduled (including a prop overhaul) have averaged $13.36 per Hobbs hour ($16/tach hour). We tend to compute by Hobbs because thats how its rented.
We majored the engine at 2,049 hours on the tach. It had good compression and was using one quart of oil every nine hours. The camshaft is estimated to be good for another 200 or 300 hours.
The most serious problem has been unnecessary and sometimes detrimental maintenance and repair. The airplane has had no inherent or persistent service problems, but bad rewiring of the gear warning system and other poorly done work has cost us in excess of $2,000 for burned-out squat switches, audio generators and the like. The work was all performed by an IA.
In conclusion, our Cutlass is a delight to fly. Its stable, has a useful load of about 1,001 pounds, and with 62 gallons of fuel has more range than we ever hope to use. A Horton STOL conversion was performed expertly by Larry Lujan and his crew at Gold Coast Aviation in Salinas. This has given us a flight envelope of better than 100 knots-from less than 35 knots Vso to greater than 140 knots at 75 percent power.
Bill and Liz Taylor
Santa Cruz, Calif.
My company purchased a new Cutlass RG in 1981. It was showing about 25 hours on the tach when delivered. As delivered, it was horribly out of rig, but my mechanics took care of that little bug in short order. I cant imagine the company test pilots and ferry pilots flying it those 25 hours being as out of rig as it was.
It now has a little more than 1,400 hours on it, and we cant praise it enough. Truly it is the best all-around airplane we have ever had.
Its flying qualities are superb. It will usually fly dirty at 43 knots, and will tolerate gentle turns at this speed. It likes to go cross country at 6,000 to 7,000 feet, and will honestly true out at a good 140 knots when flown by the book. Fuel consumption is about nine GPH at this cruise. With 62 gallons useable fuel, that gives pretty long legs.
Maintenance costs are pretty routine. We replaced a magneto at around 700 hours, and the prop spinner at about 1,000 hours due to cracking. The vernier mixture control was recently replaced due to the outer housing wearing through where it goes through the firewall. We routed the new one through a rubber grommet. This has been the most expensive part we have replaced, costing about $220.
The landing gear has been virtually trouble-free. We did have to replace the operating solenoid at about 1,200 hours at a nominal cost of $35. At annual inspection, the hydraulic system never requires more than one squirt of fluid.
If any Cutlass owners have not replaced the nose gear actuator spring guide with a metallic one, I highly recommend they do so. This is a little T-shaped affair with plastic ears. It holds the nose gear downlock in place. We replaced ours at about 500 hours and found the plastic ears badly deformed. A few more landings, and no doubt the airplane would have been on its nose. I am surprised an AD was never issued on this. At the time, it was a small job, requiring about an hour and a half of labor, and the new part cost about $7.
The airplane is very comfortable on long trips. It is quiet inside. Normal conversation is possible. The factory-installed autopilot with tracker has performed flawlessly and required no work.
Cessna certainly had their ducks in a row when they built the Cutlass RG. It is a great airplane in every respect. Dont bother to call-its not for sale.
William Polley
Enterprise, Ala.
Also With This Article
Click here to view charts for Resale Values, Payload Compared and Prices Compared.
Click here to view the Cessna 172RG Cutlass RG features guide.
