Cessna Single-Engine ADs: What’s Going On?
  • Cessna's new 172R Skyhawks and 182S Skylanes experienced a series of significant production and design problems in late 1997/early 1998, including defective mufflers, an engineering flaw causing fuel system damage, and missing structural rivets.
  • These issues, stemming from both supplier quality control and Cessna's own manufacturing challenges during a rapid production ramp-up, led to multiple FAA Airworthiness Directives and service bulletins.
  • The article highlights a heightened, strict regulatory environment from the FAA (post-ValuJet era) and suggests that if a seasoned manufacturer like Cessna struggles with proven designs, newer aircraft companies will face even greater challenges entering the certificated market.
ATISWhilemost of us were busy unwrapping Christmas gifts and ringing in 1998, executives atCessna’s single-engine plant in Independence, Kansas, were preoccupied with a ratherdistressing situation. They’d just learned that the Aeroquip-built mufflers installed inhundreds of brand new Cessna 172R Skyhawks and 182S Skylanes had potentially defectivewelds that could allow carbon monoxide contamination of the cabin via the cabin heatsystem.
The news could hardly have come at a worse time. Cessna was basically shut down for theholidays, and key staffers had to be called in on an emergency basis to evaluate theseriousness of the situation and come up with a fix…fast! The problem was first spottedin a new 182S on a late December delivery flight. The FAA decided to issue Priority LetterAirworthiness Directive 98-01-14 on December 30th, grounding the 19 affected Skylanesuntil their mufflers could be replaced.
Then, Cessna and the FAA realized that a similarproblem might exist in the 172R, and hastily-arranged pressure testing of 25 new Skyhawkmufflers confirmed their worst fears: 5 of the Aeroquip-built mufflers had leaky welds.This represented a much more serious problem, because more than 300 new Skyhawks had beendelivered to customers, and it would take months to build enough replacement mufflers toretrofit the fleet. After some quick negotiations, the FAA agreed not to ground theairplanes if their cabin heat controls were safety-wired “off” until the suspectmufflers could be replaced. This was small consolation to owners of new Skyhawks based inthe northern latitudes, of course.
1997 Cessna 172ROn January 9th, the FAA issued Priority Letter Airworthiness Directive 98-02-05requiring immediate inspection of the 172R fleet before further flight, and thesafety-wiring of cabin heat controls on those airplanes found to have Aeroquip mufflers.The AD gave owners 50 hours or 6 months to replace the mufflers. Meantime, Cessna wentinto high gear to build 300 or so replacement mufflers as quickly as possible, andinstituted a “triage” system so that the limited quantity of mufflers that wereavailable would go to where they were needed most (i.e., owners in cold-weather areas).
So many glitches, so little time
The muffler woes are just the latest in what seems like a shocking string of sweepingactions against the new Independence-built Cessnas. In June, the FAA issued an EmergencyA.D. against the entire Cessna 172R fleet (which at the time numbered only 76 airplanes)as a result of an incident that occurred during a ferry flight of a new Skyhawk to Europe.The pilot launched from St. Johns, Newfoundland, with several hundred gallons of fuel inferry tanks, but quickly became concerned that fuel consumption was much greater thannormal, and turned back. The engine quit from fuel exhaustion one-half mile short of therunway at St. Johns, and the pilot dead-sticked it in to a safe landing. Investigationrevealed insufficient clearance between the cowling, the exhaust tailpipe, and thegascolator drain standpipe. Apparently the engine rocked on its shock mounts (possiblyduring starting), causing the tailpipe to hit the cowling, the cowling to rock on itsshockmounts, and to contact and shear off the gascolator drain. The resulting Emergency ADrequired enlargement of several cowling openings, including those for the tailpipe andgascolator drain.
Then in September, an FAA inspector toured the Independence plant and discovered somerivets had been omitted from the lower forward doorpost structure of Skyhawks and Skylaneson the assembly line. The result was that on September 15th, Cessna issued sweepingService Bulletins against the entire 172R and 182S fleet (at that time, 135 Skyhawks and27 Skylanes) calling for a gruelling 14-man-hour disassembly inspection and beef-up of thedoorpost structure. Owners were given six months to comply. A week later, after someintense behind-closed-doors meetings with the FAA, Cessna decided to suspend furtherSkyhawk and Skylane deliveries until the Q/A problems could be fully addressed. Skyhawkdeliveries resumed  ten days later, and Skylane deliveries two weeks after that inmid-October.
Two months later, the leaky muffler situation came to light.
Common thread?
This recent rash of problems with Cessna’s new singles naturally prompts the question”what do these problems have in common?” The answer, as best I can determine, is”not much.”  Let’s take a closer look.
The June problem involving Skyhawk cowling interference was not a quality controlproblem. It was an engineering problem…and an understandable one at that. Prior to theSt. John’s fuel exhaustion incident, 172R’s had amassed many thousands of problem-freeflight hours. It was probably impossible to foresee that a highly-improbable worst-casecombination of manufacturing tolerances plus an unusually large movement of the powerplanton its shock mounts (possibly as a result of a backfire while starting) resulted in thetailpipe contacting the cowl and the cowl shearing off the gascolator drain. It’s almostimpossible to foresee problems like this. The resulting Emergency A.D. was the firstagainst the new Cessnas, and for the folks at Cessna’s single-engine division it wasundoubtedly as distressing as that first scratch on a new car. But like that firstscratch, a first A.D. was inevitable. Cessna and the FAA did what they had to do to makesure this highly-improbable chain of events will not recur.
The September discovery of the missing doorpost rivets was an entirely  differentmatter. This clearly was a quality control problem at Cessna, and Cessna clearlytook rather drastic measures (a highly visible suspension of deliveries plusnot-so-visible retraining of factory workers) to address it. Cessna clearly underestimatedthe difficulty of properly training its workforce during the rapid ramp-up of productionat Independence, and the September episode caused them to re-evaluate their plans toaccelerate production. Interestingly enough, although I view this as being by far the mostserious of the three problems under discussion, it was also the only one that did notresult in the issuance of an Airworthiness Directive. That’s because the FAA agreed withCessna that the missing doorpost fastners threatened only the longevity of the aircraft,not safety of flight.
The December muffler problem was also a quality control problem, but it was Aeroquip’sand not Cessna’s. Only 19 of the 70-odd 182S Skylanes had potentially leaky Aeroquip-builtmufflers; the rest had Cessna-built mufflers that did not leak. Aeroquip has been amajor aviation supplier for decades and was not new to the exhaust component business, soCessna had no reason to suspect that the company might be furnishing unsafe mufflers. Ofcourse, whoever was at fault, Cessna is ultimately responsible. Although the FAA saw fitto issue Emergency ADs requiring immediate compliance, one could well argue that this wassomething of an overreaction. As best I can determine, there was never a documented caseof carbon monoxide contamination of the cabin air as a result of these Aeroquip-builtmufflers. The leaky welds were detected only when the mufflers were pressure-tested atfive to ten times normal operating pressure. Although there’s no question that thesituation had to be addressed once it was discovered, a more relaxed compliance time(coupled, perhaps, with the requirement to put a CO detector button in the cockpit) mighthave been an appropriate response to the actual threat.
Lessons learned
Although there does not seem to be a common thread connecting these three problems withthe new Cessna singles, I do think that some observations are in order. Three lessons cometo mind:
  1. We’re living in a post-ValuJet era in which the FAA Flight Standards folks don’t seem to have much of a sense of humor, to put it mildly. The FAA took an incredible amount of heat last year for failure to report or act on known problems, and generally for “being in bed with the industry.” Well, no more. It’s pretty clear that the FAA is breathing down Cessna’s neck in Independence these days, and I sincerely doubt that Cessna is the only aircraft manufacturer under the microscope. Seems as if everyone in the aircraft manufacturer food chain from Boeing on down is under renewed FAA scrutiny these days. I fear that Admiral Busey’s “kindler, gentler FAA” is will soon be a fond but distant memory, and that the needle is swinging towards strict compliance and enforcement. God help us all.
  2. When Cessna decided to get back into the single-engine airplane business after a decade-long hiatus, there was intense pressure from many quarters for them to start producing a clean-sheet, state-of-the-art aircraft instead of the stodgy high-wing strut-braced Skyhawk and Skylane. In hindsight, it seems to me damned fortunate that they didn’t. Cessna wisely recognized that the challenges of starting up production and training a new workforce were daunting enough, without also having to deal with the inevitable problems of a new aircraft design. Given the problems that have arisen just building plain ol’ 172s and 182s, just imagine what might be going on if Cessna had decided to build the composite, glass-cockpit, fly-by-wire airplane with FADEC-controlled Dynacam engine that so many folks urged them to produce!
  3. Here’s something to ponder: if a veteran, experienced, politically-astute, deep-pocketed aircraft builder like Cessna is going through this kind of aggravation building simple aircraft like the 172 and 182, just imagine what still-wet-behind-the-ears manufacturers like Cirrus Designs, Glasair and Lancair are likely to encounter as then enter the wonderful world of certificated aircraft, product liability and FAA oversight. I sure hope they have a closet full of flack jackets and a drawer full of MIL-SPEC titanium underwear.
