Fly Right!!!
  • Modern GPS and INS navigation systems keep aircraft precisely centered on airways, ironically increasing the risk of head-on collisions if vertical separation fails due to human or technical error.
  • The danger is heightened in international airspace where communication can be poor, unit conversions may cause altitude errors, and not all aircraft are equipped with TCAS.
  • The author proposes a simple "fly right" solution: offsetting flight management systems 1 to 2 miles to the right of the airway centerline to guarantee safe lateral separation from opposite-direction traffic.
ATISThe recent mid-air between a Kazahk IL-76 and a Saudia Boeing 747 near New Delhi highlights a concern which we have been discussing between ourselves for months. While all the details may not apply; this disaster does dramatically illustrate our concern.
The modern onboard GPS and/or DME-updated IRS/INS navigational equipment has greatly enhanced the ease and accuracy of aircraft navigation. However, under certain circumstances, this accuracy could become a flight safety hazard. Airline pilots spent untold hours EXACTLY in the center of their 10 mile wide airways guaranteed only 1,000 or 2,000 feet vertical separation from opposite direction traffic. If there is a mistake during an altitude change by the crew of either aircraft, by the controller, with the communication between the two, or an autoflight equipment failure — a disaster may occur.
As international airline pilots, we spend hours and hours cruising over continents like India, China, Russia and other places where the communication could be improved (to say the least!) and the opposite-direction traffic often has no TCAS, sometimes no transponder, and might be using a slide-rule to convert altitude assignments from feet to meters or altimeter settings from inches to millibars. With that in mind, it is frightening to see the accuracy of today’s on-board navigation-systems with opposite-direction traffic. In the old days (before the advent of GPS and DME-updated IRS/INS), you could spot this traffic somewhere left or right of your own track. But these days there is no more “left or right” — the traffic is almost always right on the nose.
But there’s a simple, commonsense solution. Something we use every day when we drive to the airport. Fly right!!!
FMS navigation computers should be offset just one or two miles to the right of track. This would guarantee 2 to 4 miles lateral separation between opposite direction traffic while all aircraft would still remain well within airways. This would utilize the extreme accuracy of onboard navigational systems to both remain within airways and to provide additional traffic separation.
Had both aircraft been equipped with TCAS, the New Delhi disaster would probably have been prevented. Unfortunately, all aircraft world-wide are not so equipped. [Even in the U.S., most jet freighters don’t have TCAS. —Ed.] But even the simplest aircraft can fly a mile or two right of centerline.
Airline pilots almost daily will pass another aircraft with this 1,000 feet clearance. Wouldn’t it be much safer to also have at least two miles lateral separation? Since equipment and people do fail, why not implement this fail-safe technique?
