FAA Adds More Checks On 737 Engines
  • The FAA issued a new Airworthiness Directive (AD) for approximately 1,800 Boeing 737 aircraft in the U.S., prompted by a catastrophic engine failure on a Southwest flight in April that resulted in one fatality.
  • The AD mandates additional fan blade inspections, reducing the required inspection interval from 3,000 to 1,600 flight cycles, effective October 16.
Image: NTSB
The FAA on Monday issued a new Airworthiness Directive that affects about 1,800 Boeing 737 aircraft operated in the U.S. The AD requires additional inspections of the fan blades in all the airplanes equipped with the same type of blades that caused a catastrophic engine failure in April, when one passenger died on a Southwest flight after a window was broken by engine debris. A previous AD had mandated the inspections after 3,000 flight cycles, but the new AD reduces that interval to 1,600. The AD takes effect on Oct. 16.
The updated rule was prompted by continuing research undertaken by CFM, the engine manufacturer. CFM issued a Service Bulletin in July advising operators of the new interval recommendation. The FAA’s AD now makes that new interval mandatory. The FAA estimates each inspection will take about two hours, costing the airlines an average of about $170. If a fan blade fails the inspection, it would cost about $51,000 to replace it.
