FAA: Complex No Longer Required For Commercial/CFI Practical
  • The FAA has updated its policy, removing the requirement for commercial pilot and flight instructor applicants (single-engine airplane rating) to use a complex or turbine-powered aircraft for their practical test.
  • While the test aircraft requirement is lifted, pilots must still receive flight training and an endorsement for complex airplane proficiency under Part 61.31(e).
  • This change aims to reduce costs for applicants by allowing them to use less expensive aircraft for practical tests, with the FAA stating it will not compromise safety.
Last week the FAA released a notice regarding changes in policy regarding testing applicants for a commercial pilot or flight instructor certificate. The notice states that it is no longer required for applicants for a “commercial pilot certificate with an airplane single-engine rating to provide a complex or turbine-powered airplane for the associated practical test and no longer requires applicants for a flight instructor certificate with an airplane single-engine rating to provide a complex airplane for the practical test.”
However, under Part 61, 61.31(e), a pilot will still be required to receive flight training and an endorsement from an authorized instructor certifying his or her proficiency in a complex airplane. The notice goes on to say, “The FAA finds that no longer requiring an applicant to provide a complex airplane for the initial commercial pilot with an airplane single-engine rating practical test or a flight instructor with an airplane single-engine rating practical test will not result in a decreased level of safety.”
The FAA says it has determined that removing these ACS/PTS requirements will reduce costs for those pursuing a commercial pilot or flight instructor certificate “by allowing applicants to utilize less-expensive airplanes on the practical test that are not complex or turbine-powered.”
Read the notice here.
