AirVenture 2025 Video: Avidyne Vantage FAA Approved
Avidyne has received FAA certification for its Vantage 12 flight display.
  • Avidyne is seeking FAA certification for its new Vantage 12 retrofit flight display suite.
  • The Vantage 12 is designed for early-generation Cirrus aircraft equipped with the Avidyne Entegra, offering dual 12-inch touch displays with deep integration into Avidyne's IFD-series navigators and DFC90 autopilot.
  • While largely utilizing existing wiring, installation will require substantial panel rework, for which Avidyne provides necessary hardware to installing shops.
Avidyne has been working on FAA certification for its Vantage 12 retrofit flight display suite for early-gen Cirrus models equipped with the Avidyne Entegra. These are dual, 12-inch touch displays with deep integration with Avidyne’s IFD-series navigators and the DFC90 autopilot. The system is intended to use most of the existing wiring that’s in place but will require sizable panel rework for fit—hardware that Avidyne can offer to installing shops. Aviation Consumer Editor in Chief Larry Anglisano caught up with Avidyne’s Dan Schwinn at AirVenture 2025 for a recap.
Larry Anglisano
  1. Cool.. But I am grateful for Entegra reliability as the thought of spending 60k+ k to update two screens and two IFD without going one knot faster is just a nicety that can wait for prices to come down…
