Drone Has No Control Surfaces
  • BAE Systems and the University of Manchester have developed and flown the MAGMA drone, which uniquely controls flight without any movable control surfaces.
  • The MAGMA drone achieves three-axes control by using blown air—specifically "wing circulation control" and "thrust vectoring"—to dynamically alter its aerodynamics.
  • This innovative design offers significant benefits, including enhanced stealth capabilities due to the absence of radar-reflecting control surface deflections, simpler mechanical systems, and potential reductions in building and maintenance costs.
BAE Systems and the University of Manchester have flown a stealthy drone that has no movable control surfaces and therefore does not change shape at all in flight. The MAGMA drone uses blown air to change aerodynamics and allow three-axes control. The most obvious benefit from the innovation is that there is no deflection of control surfaces to reflect radar but there may be some advantages to the flying barn doors that most aircraft represent to radar. The new system is apparently a lot simpler than the collection of mechanical devices that now manipulate airflow around flying surfaces.
The system uses bleed air to change the physics of the air moving over the wings and stabilizers and does it in two ways. Wing circulation control blows supersonic streams of engine air at the trailing edge of the wing to change the flow of air. Thrust vectoring adds the other element of control. BAE says aircraft using its technology will be cheaper to build and maintain and be safer and easier to fly. “These trials are an important step forward in our efforts to explore adaptable airframes,” said project leader Bill Crowther. “What we are seeking to do through this program is truly groundbreaking.”
