Podcast: Trio’s Autopilot Inches Toward Approval
  • The FAA is relaxing certification requirements for avionics in certified light aircraft.
  • Trio Avionics is nearing approval for its three-axis autopilot under these new regulations.
  • Trio's certification process parallels that of TruTrak, with both companies having a strong reputation for autopilots in the experimental aviation segment.
With the FAA relaxing certification requirements for avionics in certified light aircraft, Trio Avionics is closing in on approval for its three-axis autopilot, following a parallel path to another company, TruTrak. Both are well known in the experimental segment for capable autopilots.
Duration: 6:17
File Size: 6 MB download here
