F-35 Crash in Nevada Leaves Pilot With Minor Injuries
Air Force says the aircraft went down on restricted federal property north of Las Vegas.
F-35 Crash in Nevada Range Leaves Pilot With Minor Injuries
[Credit: U.S. Air Force photo by Tech. Sgt. Betty R. Chevalier]
  • A U.S. Air Force F-35 based at Nellis Air Force Base crashed Tuesday within the Nevada Test and Training Range north of Las Vegas.
  • The pilot safely ejected with only minor injuries, and officials confirmed there was no impact to populated areas.
  • While the Air Force has not publicly confirmed the cause, reports indicate the pilot reported difficulty maneuvering the jet before ejecting.
A U.S. Air Force F-35 from Nellis Air Force Base, Nevada, crashed Tuesday in the Nevada Test and Training Range. The pilot safely ejected and sustained minor injuries.
The 57th Wing, which oversees operations at Nellis, said the aircraft went down north of Las Vegas, approximately 25 miles northeast of Indian Springs, Nevada. According to a statement, the incident occurred “within the controlled airspace and restricted federal property of the Nevada Test & Training Range.”
“Emergency responders are on-scene and there is no impact to populated areas. The pilot is safe and being treated for minor injuries. The safety of our personnel and the community remain our top priority,” the 57th Wing said in the immediate aftermath.
KSNV News 3 also reported that sources had indicated the pilot ejected after reporting difficulty maneuvering the aircraft, though Air Force officials had not publicly identified a cause.
Matt Ryan
  1. Virtually zero information - not even which version, on departure, approach, tactical maneuvering?
