NTSB Issues DCA Final Report
The NTSB has issued 33 safety recommendations following its final report on the fatal DCA midair collision.
Photo By NTSB
  • The NTSB concluded that the fatal midair collision resulted from flawed airspace design and systemic safety management failures, specifically criticizing the FAA for inadequate safeguards and ignoring known risks.
  • Key contributing factors included the FAA placing a helicopter route too close to an approach path, overreliance on visual separation in complex airspace, and high air traffic controller workload.
  • Further issues involved a blocked radio transmission, the Army helicopter flying above its assigned altitude, and limitations in both aircrafts' collision-avoidance systems.
  • The NTSB issued 33 recommendations for airspace redesign, improved collision-avoidance technology, and stronger safety management oversight to address these systemic vulnerabilities.
The National Transportation Safety Board (NTSB) released its full final report Tuesday, which determined that flawed airspace design and systemic safety management failures led to the January 29, 2025 midair collision between a regional jet and an Army Black Hawk helicopter near Ronald Reagan Washington National Airport that killed 67.
In its nearly 400-page DCA final report, the NTSB found that the Federal Aviation Administration placed Helicopter Route 4 too close to the Runway 33 approach path without adequate safeguards. Investigators said the FAA failed to act on data and repeated warnings that showed increasing midair collision risk in the DCA terminal area.
The Board also cited heavy reliance on pilot-applied visual separation in one of the country’s most complex airspace environments. On the night of the accident, the DCA tower combined helicopter and local control positions during a busy period, increasing controller workload and reducing situational awareness. A blocked radio transmission prevented the helicopter crew from hearing part of an instruction to pass behind the arriving CRJ.
Investigators said the Army crew, operating with night vision goggles, believed they had the traffic in sight but were flying above the published route altitude. The report also noted limitations in both aircrafts’ collision-avoidance systems. While the regional jet’s TCAS functioned as designed, it did not issue a higher-level resolution advisory because of altitude limits. The helicopter had no integrated traffic alerting system. Investigators said next-generation systems such as ACAS Xa and ACAS Xr could have significantly reduced collision risk.
The NTSB issued 33 recommendations in its DCA final report aimed at airspace redesign, improved collision-avoidance technology, and stronger safety management oversight.
In its probable cause finding, the Board cited the FAA’s airspace design decisions, failure to mitigate known risks, overreliance on visual separation, high controller workload, and inadequate Army oversight of altimetry procedures.
The DCA final report describes a chain of systemic vulnerabilities that investigators say were visible in safety data long before the fatal collision.
Amelia Walsh
  1. The mere fact that these flights were ever allowed to occur there, is the best example of arrogant stupidity that I can ever recall seeing.
  2. No mention of Congressional pressure to keep adding flights or to keep this airport open despite the known Secret Service desire to close it.
  3. Avatar for N6589M N6589M says:
    No mention of pilot error. Ohh I see, nothing to see.
  4. I retired in 1997 and always felt that flying into DCA at night, under VFR conditions, was an “accident waiting to happen!” Tragically, it did. HOPEFULLY, the correct steps will be taken!
  5. Much to wade through in the report, its permissions will not let me print a few pages on altimetry.
    Appears that pressure altimeter errors alone made the situation dangerous, I have not grasped what radio altimeter system of helicopter was reading. Helicopter crew apparently constrained by field of view of night-vision system. Crew monitoring is a question I have.
  6. Clarifying:
    Possible total of pressure altimeter errors.
    NTSB tested a few of the helicopter models.
    Pressure altimetry errors include:
    • manufacturing tolerances
    • wear
    • crew setting of local barometric pressure
