AVweb’s Question of the Week …
  • AVweb readers were polled on the FAA's MAP program, which funds military airports to develop "joint use" facilities for general aviation.
  • While 27% viewed the program as a wise move to immediately utilize existing facilities, a significant majority (73%) believe it is only a stopgap measure and that more dedicated GA airports are still ultimately needed.
*** PREVIOUS RESULTS ***
Last week, AVweb asked for your opinions on the FAA’s MAP program, whereby military airports receive funding to be used toward developing “joint use” facilities that will alleviate the growing strain on GA airports.  27% of you said that this is definitely a wise move on the FAA’s part, putting money into underutilized, ready-for-use facilities that can help GA out immediately.  But the vast majority of you (60% of respondents) were quick to point out that this is only a stopgap measure – while it may ease the burden of GA, more airports will still be needed.  The remaining 13% of you said emphatically that MAP alone simply won’t cut it:  When all is said and done, we still need more airports.
*** THIS WEEK’S QUESTION ***
Are professional pilots overpaid?  Answer honestly now … .
Have an idea for a new QOTW? Send your suggestions toqotw@avweb.com.
Note: This address is only for suggested QOTW questions, and not for QOTW answers.
