  • The article compiles preliminary reports of general aviation accidents that occurred in July 2018.
  • Incidents involved various aircraft types experiencing issues such as inflight upsets, takeoff stalls, inflight breakups, midair collisions, and engine power loss.
  • Several accidents resulted in fatalities or serious injuries to occupants and substantial damage to the aircraft.
AVweb’sGeneral Aviation Accident Bulletinis taken from the pages of our sister publication,Aviation Safetymagazine, and is published twice a month. All the reports listed here are preliminary and include only initial factual findings about crashes. You can learn more about the final probable cause in the NTSB’s website atwww.ntsb.gov. Final reports appear about a year after the accident, although some take longer. Find out more aboutAviation Safetyatwww.aviationsafetymagazine.com.
July 12, 2018, Tolani Lake, Ariz.
Beechcraft C90A King Air
The airplane experienced an inflight upset and was substantially damaged at about 0210 Mountain time while climbing. The pilot and passengers were not injured. Instrument conditions were reported along the route of flight; an IFR flight plan had been filed.
The pilot later reported the airplane entered an uncommanded left bank and downward pitch. The event occurred during the initial climb to cruising altitude, with the autopilot engaged and between 17,000 to 19,000 feet MSL. The pilot regained control of the airplane and continued to the destination without further incident. After landing, inspection revealed damage to both wings.
July 13, 2018, Geneseo, N.Y.
Cessna 182T Skylane
At about 1800 Eastern time, the airplane was substantially damaged during an attempted takeoff. The commercial pilot sustained serious injuries and the two passengers sustained minor injuries. The airplane was operated by the Civil Air Patrol as a familiarization flight. Visual conditions prevailed.
Earlier, the pilot had positioned the airplane to the departure airport uneventfully. During the takeoff from Runway 23, the pilot performed a soft-field procedure on the bumpy grass surface. The airplane became airborne at about 45 KIAS, and everything seemed normal as he began to climb out of ground effect at 60 KIAS. At that time, the nose pitched up abruptly. The pilot pushed the yoke forward as hard as he could while engaging nose-down electric elevator trim. However, the airplane continued to climb at an excessive angle of attack and stalled. It subsequently rolled left, descended to the ground and came to rest inverted. Initial examination revealed damage to both wings and the fuselage. The elevator trim actuator arm position corresponded to the full nose-down position. The preliminary examination was unable to document all flight control continuity. Weather observed 20 miles away at 1754 included wind from 220 degrees at seven knots.
July 13, 2018, Deer Park, Wash.
Cessna 172R Skyhawk
The airplane experienced an inflight breakup at 1021 Pacific time and collided with terrain. The flight instructor and two student pilots were fatally injured. The airplane was substantially damaged. Visual conditions prevailed.
This was the first flight in the left-seat occupant’s training program; the aft-seated student pilot was observing. Radar data indicate the airplane was at 7,000 feet MSL with an estimated groundspeed of 77 knots at 1020:53. From that point, the track made a sharp 90-degree right turn and continued on a 305-degree heading for about 3020 feet and about 20 seconds. The track then made another sharp 90-degree right turn. After about 880 feet, the last radar return at 1021:18 indicated an estimated groundspeed of 117 knots. The accident site was located about 740 feet southwest of the last recorded radar return, at 2,265 feet MSL elevation.
The wreckage was distributed over a lateral distance of 400 feet on a median magnetic bearing of about 030 degrees. Witnesses reported the airplane was in a steep dive toward terrain when both wings departed the airframe at the same time.
July 17, 2018, Fort Rice, N.D.
Cessna 152
At about 1423 Central time, the airplane impacted the Missouri River while maneuvering. The solo commercial pilot sustained fatal injuries; the airplane was substantially damaged. Visual conditions prevailed.
The pilot was conducting aerial photography operations using a handheld digital camera with a telephoto lens pointed out the left window while referencing a map on his kneeboard. At about 1330, the pilot departed on the accident flight. At about 1442, local law enforcement was notified the airplane was in the Missouri River. The airplane was discovered nose down at a 65-degree angle, in about five feet of water. After the airplane was recovered from the river, examination revealed no preimpact mechanical malfunctions or failures.
July 17, 2018, Miami, Fla.
Piper PA-34-200 Seneca/Cessna 172N Skyhawk
The two airplanes collided in midair at 1259 Eastern time. The Piper was destroyed, and the private pilot and designated pilot examiner (DPE) aboard were fatally injured. The Cessna was destroyed; its flight instructor and student pilot also were fatally injured. Both airplanes were registered to and operated by the same operator. Visual conditions prevailed.
Preliminary information indicates the Piper was enroute to a nearby training area at about 1,500 feet MSL and was outside the local Class D airspace. The Cessna was returning from the training area and had contacted ATC to enter the Class D airspace just prior to the collision. The controller acknowledged the Cessna and issued a traffic advisory, but no further communications were received. A review of radar data revealed the two targets converged nearly straight on. At the time of the collision, the Piper was flying northwest and the Cessna was flying southeast. Weather observed at 1253 included visibility of 10 sm and scattered clouds at 3,500 feet and 4,200 feet AGL.
July 17, 2018, Truckee, Calif.
Ryan Navion B
At about 0734 Pacific time, the airplane experienced a loss of engine power shortly after takeoff. The private pilot and one passenger sustained fatal injuries; one passenger was seriously injured. The airplane was substantially damaged during the subsequent emergency landing. Visual conditions prevailed.
Shortly after takeoff from Runway 11 and during the initial climb, the pilot reported to ATC he had experienced a power failure and would be returning to the field. During the right turn, the airplane lost altitude, impacted terrain in a flat attitude and came to rest upright about a mile southeast of the departure end of Runway 11.
This article originally appeared in the October 2018 issue ofAviation Safetymagazine.
