  • Several general aviation accidents in January 2018 involved landing gear failures, including separations and collapses, during or immediately after landing.
  • Incidents of spatial disorientation, loss of communication/control, and navigation errors led to crashes, including a dark night road landing and an aircraft disappearing over the Gulf of Mexico.
  • Fatal accidents included a helicopter impact with terrain resulting in multiple casualties and a plane colliding with mountains after encountering turbulence.
  • Other incidents involved critical flight phase failures such as an engine power loss shortly after takeoff, leading to a forced landing, and an aerodynamic stall due to a downdraft.
AVweb’s General Aviation Accident Bulletin is taken from the pages of our sister publication, Aviation Safety magazine, and is published twice a month. All the reports listed here are preliminary and include only initial factual findings about crashes. You can learn more about the final probable cause in the NTSB’s website at www.ntsb.gov. Final reports appear about a year after the accident, although some take longer. Find out more about Aviation Safety at www.aviationsafetymagazine.com.
January 1, 2018, Lynchburg, Va.
Costruzioni Aeronautiche Tecnam P2006
At about 1725 Eastern time, the airplane sustained substantial damage following a landing gear separation during landing. The flight instructor in the right seat and the pilot receiving instruction in the left seat sustained no injuries. Visual conditions were present.
As the flight turned onto final approach, and with the flaps fully extended, the aircrew verified verbally that all landing gears were down and locked. The pilot maintained about a 500-fpm descent on final and verified verbally with the flight instructor that the airspeed was 70 KIAS. The pilot flared and executed a normal landing. Immediately after touchdown, the left main landing gear assembly separated at the axle. Subsequently, the airplane skidded for about 100 feet, departed the runway to the left and came to rest on the grass. The pilot performed a shutdown and the two occupants egressed without further incident.
The flight instructor reported there were no wind gusts during the approach and landing, and there was no side loading at touchdown. The flight instructor further reported that in his experience, he did not feel the landing would have caused any damage.
January 1, 2018, Nampa, Idaho
Cessna 150
The pilot later reported becoming disoriented on a dark night. He circled over a nearby town for about an hour, but was unable to find any visual references to aid in navigation. The pilot then called a family member on the ground, who provided guidance to the destination airport via a cellphone app. He spotted what appeared to be the destination airport and maneuvered for an approach but realized in the landing flare he was not at the airport. Instead, the pilot landed on a road about six miles from his intended destination. During the landing, the airplane struck trees, landed on a road, veered left and impacted a light pole.
January 2, 2018, Aurora, Ore.
Cessna T210L Turbo Centurion
At about 0920 local time, the airplane was substantially damaged when its right main landing gear collapsed during landing. The solo private pilot was not injured; visual conditions prevailed.
After failing to obtain indications that the landing gear was down and locked, the pilot flew a low approach, after which tower personnel reported that the landing gear appeared to be down. During the landing, the right main landing gear collapsed, followed by the airplane veering off the right side of the runway. The airplane sustained substantial damage to the right elevator and right horizontal stabilizer.
January 3, 2018, Gulf of Mexico
Cirrus Design SR22T
At about 1800 Central time, the airplane was missing over the Gulf of Mexico and presumed sunk. Visual conditions prevailed. The flight departed Oklahoma City, Okla., at about 1419 with Georgetown, Texas, as its destination.
As the airplane approached the destination airport, ATC cleared it to turn right and descend to 13,000 feet msl. Instead, the airplane turned left. Controllers made multiple attempts to communicate with the pilot, but without success. Radar tracked the aircraft to its last known position about 220 miles north of Cancun, Mexico.
January 11, 2018, Elko, Nev.
Piper PA-23-250 Aztec
At about 1800 Pacific time, the airplane collided with mountainous terrain. The solo commercial pilot was fatally injured; the airplane sustained substantial damage. Visual conditions prevailed.
While en route, the pilot reported encountering clouds and asked for the nearest airport, saying, “Alright, I’m getting super turbulent over here I’m going to head over there.” Shortly after, communication and radar contact were lost. Search and rescue efforts ensued, and aerial photography was used to identify the crash site January 19, 2018, on the east face of mountain peak, near its summit. Onsite examination by ground personnel identified the wreckage as the accident airplane.
January 13, 2018, Longmont, Colo.
Beech K35 Bonanza
The airplane experienced a loss of engine power shortly after takeoff. The pilot sustained serious injuries, the passenger sustained minor injuries and the airplane sustained substantial damage. Visual conditions prevailed.
A witness heard “a popping noise” coming from the accident airplane during takeoff. A few seconds later, he heard the engine “shut off” with the airplane in a nose-up attitude. The airplane rolled to the right and then descended in a “steep dive” toward the ground. When the witness arrived at the accident site, he observed smoke and smelled fuel near the airplane. He stated the ground near the airplane was wet and fuel was leaking from the wing where it had separated from the fuselage. The pilot later told the owner that after the second consecutive touch-and-go, the engine lost power so the pilot pushed the nose down and made a forced landing in a field off the end of the runway. The pilot added that the landing gear had already been retracted and there was no remaining runway available to land.
January 17, 2018, Raton, N.M.
Bell UH-1H Helicopter
At about 1800 Mountain time, the helicopter impacted terrain; a ground fire and explosion subsequently occurred. The commercial pilot, pilot-rated passenger and three other passengers were fatally injured. One passenger sustained serious injuries. The helicopter was destroyed. Night visual conditions prevailed.
The surviving passenger indicated the helicopter was in level flight and recalled a big bang as the helicopter hit the ground. The helicopter rolled forward, coming to a stop upside down with the passenger hanging from a seat belt and jet fuel pouring on her. The passenger released her seat belt and evacuated the helicopter. The helicopter was on fire and subsequent explosions followed. The passenger called 911 and waited for emergency responders.
Weather at the departure point 10.7 nm from the accident site included wind from 030 degrees at 10 knots, visibility of 10 sm and clear skies. The fuselage came to rest on a flat mesa at the top of rising terrain. The elevation in the area of the main wreckage was about 6932 feet msl. The initial observed point of terrain contact was a parallel pair of ground scars, consistent with the width of the helicopter’s landing skids, which led directly to the main wreckage on a 074-degree bearing. The distance from the start of the parallel ground scars to the wreckage was about 474 feet.
January 17, 2018, Skyforest, Calif.
Mooney M20E Super 21/Chaparral
The airplane collided with rising terrain at about 1130 Pacific time. The private pilot and one passenger sustained minor injuries; two other passengers were not injured. The airplane sustained substantial damage. Visual conditions prevailed.
The pilot reported departing with 20 gallons of fuel aboard. About five minutes into the flight, the airplane approached terrain that rose from about 1800 feet msl to 5700 feet over about 5.5 miles. The airplane was about 1000 feet agl as it neared the top of the ridgeline. The pilot stated he encountered a downdraft and the airplane aerodynamically stalled. Seconds later, the airplane impacted terrain.
This article originally appeared in the April 2018 issue of Aviation Safety magazine.
