  • The article presents preliminary findings for multiple general aviation accidents that occurred in January 2019, compiled from Aviation Safety magazine.
  • A common factor in many of these incidents was the partial or complete loss of engine power, stemming from diverse issues such as mechanical failures, carburetor icing, or control problems.
  • These engine malfunctions frequently necessitated forced landings, leading to substantial aircraft damage and varying degrees of pilot and passenger injury, including fatalities.
AVweb’sGeneral Aviation Accident Bulletinis taken from the pages of our sister publication,Aviation Safetymagazine. All the reports listed here are preliminary and include only initial factual findings about crashes. You can learn more about the final probable cause on the NTSB’s website atwww.ntsb.gov. Final reports appear about a year after the accident, although some take longer. Find out more aboutAviation Safetyatwww.aviationsafetymagazine.com.
January 13, 2019, Adrian, Mich.
Piper PA-32R-300 Lance
At 1746 Eastern time, the airplane was substantially damaged when it landed short of the runway after its engine failed. The airplane impacted a fence and terrain; the solo private pilot received minor injuries. Visual conditions prevailed.
Post-accident examination of the Lycoming IO-540-K1G5D engine revealed a crankshaft gear bolt, p/n 13S19649, was fractured. The engine logbook stated an AN8-14 bolt had been installed. The illustrated parts catalog and a mandatory service bulletin specified an AN8-14A bolt.
January 13, 2019, Port Hadlock, Wash.
Beechcraft B35 Bonanza
The airplane collided with trees at about 1400 Pacific time following a loss of engine power. The solo commercial pilot received minor injuries; the airplane was substantially damaged. Visual conditions prevailed.
The pilot reported that shortly after takeoff the cockpit door opened, and that while turning onto left downwind to return to the runway, the engine lost power. The pilot subsequently initiated an off-airport forced landing, during which the airplane struck a stand of trees.
January 15, 2019, Salt Lake City, Utah
Piper PA-28-140 Cherokee 140
At about 1050 Mountain time, the airplane landed hard on a road following a partial loss of engine power during a go-around. The solo commercial pilot was not injured. The airplane sustained substantial damage to its landing gear and right wing. Visual conditions prevailed.
While on final approach, the airplane was high, so the pilot initiated a forward slip to lose altitude. He reduced the throttle but instead of decreasing, engine rpm increased. The pilot opted to initiate a go-around to troubleshoot the problem, retracted the flaps and added full throttle control. The engine would only develop about 1500 rpm, however, which was not sufficient to maintain altitude. The airplane continued beyond the runway and subsequently landed on the road.
January 17, 2019, Ellensburg, Wash.
Piper PA-23-250 Aztec
The airplane impacted terrain at about 1645 Pacific time. The solo commercial pilot was fatally injured and the airplane was destroyed. Visual conditions prevailed.
A witness about 2300 feet from the accident site reported observing the airplane about 200—300 feet above the ground, “diving down sideways.” Another witness reported seeing the airplane at about 300 feet AGL and heard the engines “gunning.” He observed the air plane impact the ground at about a 45-degree angle, right-wing low.
January 18, 2019, Beechwood, Wis.
Piper PA-24-250 Comanche 250
At about 1520 Central time, the airplane was substantially damaged during a forced landing after a partial loss of engine power. The solo private pilot sustained minor injuries. Visual conditions prevailed.
The pilot was cruising at 3000 feet MSL when he noticed the carburetor temperature gauge moving through the yellow arc (cooling) toward the red arc (getting colder). About the same time, the engine began to lose power and rpm was dropping. The pilot performed remedial actions and, after applying carburetor heat, engine roughness worsened. With only partial power, the pilot selected a field for a gear-up forced landing.
January 19, 2019, Keshena, Wis.
Stinson 108 Voyager
The airplane impacted trees and a road at about 1130 Central time during a forced landing. The pilot and one passenger sustained serious injuries and two passengers sustained minor injuries. The airplane sustained substantial damage. Visual conditions prevailed.
While in cruise, the engine experienced a momentary and substantial loss of rpm. The pilot enrichened the mixture, activated the carburetor heat and switched fuel tanks. The engine recovered and the pilot left the carburetor heat on for about three minutes, then slowly turned it off. About two minutes after the carburetor heat was turned off, the engine ceased producing power. The pilot reported that once the engine stopped, it did not “windmill” and the starter would not engage. An asphalt road with trees on both sides was chosen for a forced landing. During the landing, the airplane impacted the trees and bounced on the road, coming to rest upside down on a snow-covered embankment.
January 21, 2019, Kidron, Ohio
Douglas DC-3C
At about 0912 Eastern time, the airplane was substantially damaged during a takeoff attempt. The captain and first officer were fatally injured and the airplane sustained substantial damage. Visual conditions prevailed for the positioning flight.
A witness observed the airplane lift off about a third of the way down the runway. Soon after it became airborne, white smoke was seen coming out of the left engine. The airplane began to veer to the left and did not climb normally. The witness watched the airplane descend over a building until he lost sight of it. The airplane struck power lines and trees before impacting the ground and came to rest about 200 yards beyond the runway’s departure end.
This article originally appeared in the April 2019 issue ofAviation Safetymagazine.
