Knowing Known Ice
  • Icing regulations and aircraft certification standards have evolved significantly, creating complexity, especially for older aircraft certified before modern "Flight Into Known Icing" (FIKI) protocols.
  • An aircraft's ability to safely handle ice varies greatly based on its design, power-to-weight ratio, and the specific icing conditions encountered; FIKI certification does not mean an aircraft can withstand all types of ice.
  • Pilots are primarily responsible for understanding icing conditions, respecting their aircraft's limitations, and exercising common sense, as current certification standards (Appendix C) do not encompass all natural icing phenomena like freezing rain or supercooled large droplets (SLD).
Transitioning to your first aircraft that has ice protection equipment beyond a heated pitot tube is a big step for a pilot. Having a full complement of ice protection usually gives pilots warm fuzzy feelings about being able to complete more trips and handle any ice related problems that arise. Unfortunately, the current regulations and guidance addressing icing can be just as complex as dealing with the nuances of inflight icing encounters.
Case in point is the FAAs recently proposed Airworthiness Directive for 300 and 400 series twin Cessnas produced in the early 1970s and before (Federal Register Docket FAA-2011-0562). The AD would prohibit all covered aircraft from flight into icing conditions because these aircraft were not required to demonstrate adequate ice protection performance when produced. Performance wasnt demonstrated because no certification basis existed under 14 CFR Part 23 when they were built.
And thats the problem. Certification standards for flight into known icing (FIKI) have changed drastically over the years, as has the very definition of what even constitutes icing conditions, and its always difficult to hit a moving target. Lets get to the bottom of what it takes to fly in ice in the current regulatory environment.
Ice Protection Certification
If you fly a relatively new aircraft that is FIKI certified, you should have some confidence in knowing that modern icing certification is a rigorous process which involves demonstrating safe flight in specific icing conditions, known in the regs as Appendix C Icing Conditions. However, it wasnt always this way. This is where much of the is it? or isnt it? confusion arises for pilots flying many older aircraft.
It would be great if every aircraft flying today adhered to the same type certification standards, but thats not the case by a long shot. Every individual type was required to comply with the standards in place on the date of its certification by the FAA. That certification basis is listed in the aircrafts Type Certificate Data Sheet (TCDS). This gives you the key to determining the ice protection standards that were required for certification.
Prior to 1974, there effectively werent any FAA standards for general aviation icing certification. During this period, aircraft were not specifically allowed or disallowed from flight into icing conditions by the FAA, and any published limitations were made by the manufacturer. In 1974, certification standards were added for general aviation aircraft that parallel transport category ice certification.
For many older ice-flying aircraft, there have been thousands of hours flown in real-world icing conditions, and the word on the street from pilot groups, while probably not as rigorous as current FAA certification standards, is certainly more thorough than what most test flights can accomplish. Therefore, it is beneficial to investigate the certification standards for your aircraft as a way of predicting future FAA interest in the icing capabilities of your aircraft type, such as with the proposed twin Cessna AD.
Does It Carry Ice Well?
One of the first questions a pilot will ask when transitioning to an aircraft with ice protection is about how well it carries ice. This is a reasonable and insightful question to ask. Every aircraft carries ice differently, with the variability coming from the wing shape, type of ice protection being used, type of ice encountered and a variety of other factors. In my experience one of the biggest factors is the power to weight ratio. After all, given enough horsepower you can make an ice-laden barn fly.
Back in my freight dog days, I primarily flew the Cessna Caravan, a great flying airplane with a bit of a bad reputation (partially deserved, partially undeserved) when it came to ice. The Caravan certainly had ramp presence. It was big. Even with that 675 shp engine hanging off the nose, it was actually underpowered. That engine had to pull an aircraft that maxed out at 8,550lbs with the cargo pod. This yields a power loading ratio of 12.67 pounds per horsepower.
An aircrafts ability to climb is directly related to power in excess of that required to maintain level flight and is of critical importance when dealing with an icing encounter. The Caravan was a deceptively easy plane to fly, but its lack of excess power is the root cause of its icing reputation. The Caravan could certainly carry a load of ice, but because of the lack of available power to climb, the pilot simply wasnt permitted as much time to form a plan to deal with an icing encounter as might have been allowed in another aircraft type.
Keep in mind that the power being considered here is the available horsepower, which decreases with altitude for normally aspirated aircraft. Additionally, remember that ice is heavy, and that the bigger the physical size of your aircraft, the more unprotected surfaces will become contaminated and the quicker weight will build due to ice accumulation. So if your aircraft is already at its maximum weight (in the absence of an ice weight limitation), picking up ice could mean you have become over gross weight while aerodynamically compromised. Thats not a good combination.
Knowing Conditions
The current standards for ice certification for both normal and transport category aircraft are limited to the scientifically described icing conditions documented in Appendix C of FAR Part 25. A challenge for pilots flying aircraft certified under that section is being able to correlate those scientific standards with what theyre seeing out- side and identifying conditions that exceed those standards. Specifically, supercooled large droplet ice (SLD), freezing rain and freezing drizzle, all of which cause ice accumulations aft of protected surfaces, are outside of the standards for any aircraft.
For a long time, known icing conditions were only defined by case law and legal interpretations. In 2006 an FAA interpretation attempted to define it as temperatures at or below freezing in visible moisture, which effectively meant any clouds in the winter. In 2009 they backpedaled into a surprisingly common-sense definition that known icing conditions exist when a reasonable and prudent pilot would know of them based on all the weather information available at that time.
Now the responsibility is on the pilot to become educated into understanding what causes ice, self-certify that a proposed flight will not exceed his aircrafts icing capabilities and make contingency plans for unforecast icing encounters. For aircraft lacking a FIKI certification, that means steering clear of all forecast ice. For known-ice aircraft, that means steering clear of all forecast ice that exceeds limitations on the aircraft type, or common sense.
The graphical weather products that are available today make planning to avoid ice much easier than even a few years ago. AIRMETs and SIGMETs, combined with freezing level graphics and pilot reports, supplemented with the Current/Forecast Icing Potential graphics, give pilots many valuable tools to use. Part of the challenge of forecasting ice is its fickle nature-as air masses evolve, icing conditions in an area can change significantly over a short period of time. Therefore, on an IFR winter flight thats expected to be clear of ice, always pay attention to conditions that dont seem to be supporting your preflight analysis.
Developing a Known-Ice Pilot
FAA certification of an aircraft for flight in icing conditions encourages the already common misconception that its safe to fly in icing conditions and that pilots can relax. This is an important point that cant be overstressed. Just because an aircraft is granted known icing certification by the FAA, even using todays more stringent standards, does not constitute an authorization to fly in any conditions. In fact, for most aircraft and GA aircraft in particular, FIKI certification should be viewed by the pilot as merely an ability to transit brief icing encounters, not to fly through ice for hours.
Like so much in aviation, we know a lot more about ice today than we did a few years back, but were still a long way from knowing all there is to know. Having a defined standard for ice protection is certainly useful, but it is not sufficient. Were always reading about aircraft that have met all?the modern Part 25, Appendix C, certification standards finding out exactly how much ice is too much for their aircraft type, and paying dearly for the discovery. Unfortunately, Mother Nature doesnt always adhere to the Appendix C definition of ice.
Consider one of the findings made by the NTSB after the 1994 ATR-72 crash in Roselawn, Indiana:
The 14 CFR Part 25, Appendix C, envelope is limited and does not include conditions of freezing drizzle or freezing rain; thus, the current process by which aircraft are certified using the Appendix C icing envelope is inadequate and does not require manufacturers to sufficiently demonstrate the airplanes capabilities in all the possible icing conditions that can, and do, occur in nature.
I suspect well never be able to demonstrate capabilities in all possible icing conditions that Mother Nature can throw at us. Therefore, safety in icing conditions should be primarily a factor of pilot education, respect for the pilots and the aircrafts limitations and the rarest and most valuable asset there is: common sense.
A version of this article appeared in the January 2013 issue of IFR Magazine.
