AirVenture Spotlight: Sling It!
The Sling High Wing prototype leads the first High Wing taildragger off the taxiway after nearly 70 hours of flying from South Africa.
  • South African airframer Sling successfully flew three new High-Wing aircraft (prototype and two production models) from Johannesburg, South Africa, to Oshkosh, Wisconsin, for AirVenture.
  • The impressive journey covered 67.5 flying hours over 10 days, including a significant transatlantic leg, with no issues reported by the crews.
  • This long-distance flight served to spectacularly introduce and demonstrate the capabilities of Sling's new High-Wing variation.
  • Following the flight, the two production aircraft will remain in the U.S. with their owner/builders, while the prototype will return to South Africa.
Keen to show off their new High-Wing variation of the well-regarded low-wing TSi, South African airframer Sling has done so in spectacular fashion by flying the prototype and production serial numbers one and two from Johannesburg, South Africa, to Oshkosh, Wisconsin. The trio landed at AirVenture yesterday afternoon.
Serial number 2 Sling High Wing is this taildragger. The strut-less wing, composite center-fuselage bodywork and extensive flush riveting make the design more slippery than most.
An effusive James Pittman of Sling used a marking pen to describe some wildly small but vertical geography sighted during the Joburg-Oshkosh flight.
The epic jaunt was flown in daylight in legs up the west African coast to the Cape Verde Islands, then the big jump westward across the mid-Atlantic to the Barbados, Bahamas, Florida and finally Oshkosh. The trio arrived to a hugely exuberant contingent of family, friends, the crew from the Sling Aircraft booth plus a phalanx of photographers and reporters.
While the official statistics will come soon enough, the first look at the numbers say the trip took 67.5 flying hours over 10 days. Fuel burn from the Rotax 915iS engines was guesstimated as between 29 and 35 liters per hour—in the 7 to 9 gph range—at 140 knot airspeeds. Winds were favorable over most of the route, save for 25 knot headwinds in the middle of the U.S. leg.
Linda Sollars, Matt “Bulldog” Cohen, J.P. Schultz and James Pittman celebrate their “Joburg to Oshkosh” flight.
No issues were encountered on the flight and the crews said they were often ready for more flying. They were certainly energetic in their enthusiasm upon their AirVenture arrival.
Plans for the three aircraft vary. The prototype will return to South Africa while the two N-numbered production aircraft, which were flown by their owner/builders on the hemispheric-trotting ferry flight, will remain in the U.S.
The Joburg-Oshkosh adventure was just the latest of long-distance Sling flights. As this map on the prototype High Wing shows, flights from South Africa to Madagascar, Belgium, Poland, an earlier Oshkosh flight and two round the world flights are already in the books.
This article originally appeared in KITPLANES. For more great content like this, subscribe to KITPLANES!
Tom Wilson
Tom Wilson got into general aviation in 1973 after pumping avgas and waxing flight school airplanes, but the lure of racing cars and motorcycles sent him down a motor journalism career heavy on engines and racing. Today he flies for fun in a Starduster and a shared Cessna 140A.
