Understanding Flow Control
  • Air traffic control uses various methods like flow control, metering, and IFR slots to manage congestion and mitigate delays.
  • Tools such as Ground Delay Programs (GDP), LAHSO (Land and Hold Short Operations), and Surface Management Guidance and Control Systems (SMGCS) enhance efficiency and safety.
  • Pilots can utilize strategies such as TEC routes, preferred IFR routes, and STARs (Standard Terminal Arrivals) to minimize delays during flight planning.
  • Staying informed about NOTAMs and traffic delays, as required by FAR 91.103(a), allows pilots to make more informed decisions and contribute to smoother air traffic flow.
No one needs to tell you that air traffic congestion can delay issuance of your IFR clearance or cause you to suffer the dreaded Hold for IFR Release call with an indefinite departure time while the Hobbs goes tick, tick, tick.
NextGen, the FAAs wide ranging overhaul of the Air Traffic Control System, is supposed to eliminate many delays by making the most efficient use of airspace and airports. In part, this is an acknowledgement that simply building more airports is not the answer due to cost, space and environmental issues to name a few, even though airports are responsible for about a third of flight delays.
Safety is the invisible elephant constraining any proposal to increase capacity. There is only so much airspace and so many airports. How then to make best use of what we have?
Flow Control
The answer is flow control. By regulating the rate at which aircraft enter congested resources such as airport airspace to a level no greater than the resource can accept, bottlenecks can be mitigated if not avoided altogether.
A related term, metering, regulates the time of arriving traffic into a terminal area so as not to exceed a pre-determined terminal acceptance rate.
IFR Slots are one way ATC exercises flow control. Back in 1968, traffic saturation at five critical airports (LaGuardia, Kennedy, Newark, Dulles and OHare) forced the FAA to institute the high density rule that limited the number of IFR departures and arrivals during certain hours of the day. The resulting time slots were allocated to air carriers for IFR landings and takeoffs during a particular 30 or 60-minute period. That rigid process has since become more flexible, but it has also become more conservative relative to the evolution of streamlined ATC technology. Ironically, the slot system at times becomes a constriction point working against the very efficiency it was designed to create.
Bad weather forces runway arrival rates down, due in part to time-consuming SIDs and STARs. In 1999, Ground Delay Program (GDP) software introduced a form of flow control in which it reduced airline arrival slots for aircraft headed toward weathered-in airports. As its name implies, aircraft are held on the ground at their origin, resulting in less expense and greater safety than in-flight holds.
Todays Enhanced GDP reassigns slots made vacant by cancellations or delays and fills them with operating flights.
Lasso that LAHSO
One easy way to increase runway capacity is via LAHSO-Land and Hold Short Operations, something we can do very well in GA.
At airports with operating towers and intersecting runways or taxiways, the tower may ask, Can you land and hold short of runway 31, 3600 feet available. They can also specify a hold-short point on a runway.
Its up to you to accept or reject it as you wish, but student pilots or those unfamiliar with LAHSO should not participate. A LAHSO clearance does not preclude your right to reject the landing and go around, but once you accept the clearance you are obligated to comply with it like any other clearance. If you subsequently need to reject the landing, you are expected to safely separate yourself from other aircraft and promptly notify the controller.
Airports that conduct LAHSO are listed on page O-1 of the FAA U.S. Terminal Procedures Publication as well as in the A/FD. If LAHSO are in effect, that fact will be stated on the ATIS or AWOS.
In the future LAHSO may be extended to include wet runways where mixed commercial and GA operations are in effect and might include multiple hold-short points on a runway.
Surface Management
Surface Management Guidance and Control System (SMGCS) consists of a computer-generated low-visibility taxi plan for airports able to launch or land when the RVR is less than 1200 feet-for both air crews and airport vehicles. SMGCS (pronounced SMIGS) designates taxi routes to and from SMGCS run- ways and displays them on a special SMGCS Low Visibility Taxi Route monitor in the tower.
A SMGCS chart makes it possible for pilots and drivers to find their way during low visibility and keep aircraft and vehicles where they are supposed to be. Jeppesen publishes Low Visibility Taxi Route Charts for cockpit use.
Strategically, SMGCS is the ground component that aligns with stream-lined arrival and departure management and the en route components of free flight. Taken together, they are supposed to form a system that minimizes delays and enhances safety during each phase of flight.
Save Time With TEC
TEC stands for Tower En Route Control, and is referred to as tower en route or tower-to-tower. This is a misnomer because you dont talk to towers en route, you talk with TRA-CONs. Filing a TECroute means that you stay in approach control airspace all the way and never enter the en route system controlled by ARTCC. It is designed to service non- turbojet aircraft going to and coming from metropolitan centers at altitudes below 10,000 feet and for flights of two hours or less. Beyond that length, extensive coordination between facilities may create undue delays.
TEC flights may experience the same departure, destination and en route delays as any other ATC-controlled aircraft would. In this case you may prefer an alternate destination airport with no delays.
There are no special pilot or equipment requirements because TEC uses the Victor airways. TEC routes are published in the A/FD. Simply specify TEC in the Remarks section of your IFR flight plan. You have the flexibility of filing to a satellite airport near the major primary airport via the same routing.
Not all approach control facilities may operate up to the maximum TEC altitude of 10,000 feet. This may be a concern if you want to get above any weather.
Historically, TEC became important back in 1981 when the controllers went on strike. This is because TEC was designed to be an overflow resource in the low-altitude system. It worked pretty well.
Preferred IFR Routes
Preferred routes are published in the A/FD for both low and high altitude stratum. They are also available as an option in most flight planning soft- ware. Preferred IFR routes have the advantage of minimizing in-flight route changes, are designed to use airways in an efficient, orderly way and help systematize air traffic flow. The more you use preferred routes, the better for all participants in minimizing departure, en route and arrival delays.
File By The STARs
One of my favorite ways of filing is to find a STAR that takes me to my desired airport and then flying it almost from departure. By doing this, you minimize delay by following a standard, published route that weaves you through sometimes complex airspace.
For instance, when I go north, I file the Bairn Three Arrival into the Orlando, FL (KSFB) area from Palm Beach (PBI), which is just five miles north of my home airport. Usually the controllers will fly me west of PBI and join the PBI 330 radial to the northwest. I can fly into any of the five airports in the Orlando area, which provides more flexibility in flight planning.
FAR 91.103 (a)
This provision of the FAR requires the pilot to be aware of any known traffic delays of which the PIC has been advised by ATC. You can take this one step further and ask for published NOTAM delays during your flight briefing. Although the readout can be somewhat cryptic, you can get the essence by reading it slowly. Note that it begins with the acronym ATCSCC – the ATC Systems Command Center in Warrenton, VA. ATCSCC regulates air traffic when weather, equipment, runway closures, or other conditions place stress on the National Airspace System.
ATCSCCs Enhanced Traffic Management System (ETMS) predicts traffic surges, gaps, and volume based on current and anticipated airborne aircraft. Personnel evaluate the projected traffic flow into airports and sectors, and then take the least restrictive action needed to assure that system capacity is not exceeded.
Within ETMS, the Monitor Alert analyzes traffic demand for all airports, sectors, and airborne reporting fixes in the continental U.S. It automatically displays an alert when demand is predicted to exceed capacity in a specific area. Again, personnel examine the circumstances and then provide routes and spacing to promote traffic flow.
Some things we can control and others not. The FAA is doing its best to minimize system delays. We can help ourselves, however, by making use of what they give us and by being intelligently creative in our IFR filings. As always, being smart on the ground will make your flight easier, safer and faster.
This article originally appreared in the June 2013 issue of IFR Refresher.
