Unleaded Avgas Airport Playbook Lands Before Final FAA Plan
June publications from the National Academies put the unleaded fuel transition in the hands of airport operators.
[Credit: Richard Thornton | Shutterstock]
  • While the FAA's final unleaded transition plan remains pending, federal legislation requires airports to maintain 100LL access through 2030 unless an approved, universal unleaded replacement becomes widely available.
  • A new Airport Cooperative Research Program (ACRP) guide provides airport operators with practical tools—including fleet surveys, checklists, and cost evaluation models—to prepare for the shift ahead of finalized federal details.
  • Because emerging unleaded fuels vary in ASTM standardization and Supplemental Type Certificate (STC) eligibility, local airports face unique operational challenges regarding tank capacity, dual-fuel logistics, and misfueling risks.
  • With broad regulatory and economic questions still unresolved at the national level, the practical burden of navigating the unleaded transition is increasingly falling on local airport management and aircraft owners.
The June publication of a new Airport Cooperative Research Program guide arrives during a very much unresolved stage of the federal unleaded avgas process.
The FAA’s comment period on its draft Transition Plan to Unleaded Aviation Gasoline closed earlier this year, and as of this writing, the final plan has not been published, nor has the agency released the public comments it received.
“Our priority is releasing the Transition Plan,” the FAA said in response to an AVweb status inquiry. “We will do that first and then release the comment summary in late 2026.”
That leaves airports and aircraft owners preparing for a transition whose direction is established while many of its key governing details remain pending. The National Academies Press published Transitioning to Unleaded Aviation Gasoline, A Guide and Tools in June, along with a companion primer. The documents were developed under ACRP Project 03-73, sponsored by the FAA and administered by the Transportation Research Board.
It is important to mention that they do not attempt to replace the FAA transition plan. They instead serve a different purpose of bringing the national effort down to the airport level to address some of the practical issues they will face as the transition moves forward.
Federal Policy Meets Airport Operations
Most who have any skin in the game when it comes to the upcoming unleaded avgas transition are probably well aware of the history, but a bit of background before we dive in.
In 2023, the Environmental Protection Agency issued its finding that lead emissions from aircraft engines operating on leaded fuel endanger public health and welfare. The ACRP primer says leaded aviation gasoline is now the largest current source of airborne lead emissions in the United States, after the phaseout of leaded automotive gasoline and reductions from other sources.
“Lead emissions from aircraft are an important and urgent public health issue,” the EPA said. “Lead exposure can have harmful effects on cognitive function, including reduced IQ, decreased academic performance, as well as increased risk for additional health concerns. There is no evidence of a threshold below which there are no harmful effects on cognition from lead exposure.”
Congress has also defined part of the airport problem. The FAA Reauthorization Act of 2024 requires airports that offered leaded avgas in 2022 or earlier to keep it available until Dec. 31, 2030, unless an FAA-authorized unleaded avgas replacement for nearly all piston-engine aircraft and engines is available and meets a standard the agency considers acceptable for safe use, production and distribution.
That requirement preserves 100LL access for aircraft that still need it, at least for the moment. It also creates the transitional period that airport operators now have to manage. Some fields have the tankage, staff and fuel volume to add an unleaded avgas option before leaded fuel disappears. Others have a single avgas tank, a small based fleet and little operational room for parallel fuels.
The ACRP guide’s starting point is that difficulty. Its recommended process begins with fuel suppliers and FBOs, then moves through local fleet compatibility, demand estimates, infrastructure review, funding options, financial analysis, unleaded avgas selection, implementation, safety procedures, training and continued monitoring. The sequence treats fuel choice as the product of airport-specific information and decisions.
The Fuel Snapshot Needs A Date Stamp
The report is a June publication, but its fuel-status discussion reflects information available when the guide was being prepared in January 2025. At that point, it identified non-oxygenated mogas, Swift Fuels UL94, GAMI G100UL and Swift Fuels 100R as unleaded avgas options that were commercially available or moving toward commercial availability. UL100E from LyondellBasell and VP Racing Fuels remained in FAA testing.
Of course, unleaded avgas availability is not the same as universal usability. Mogas, UL94, G100UL and 100R depend on STCs unless the aircraft’s type certificate already allows the fuel. The guide acknowledges this, and also describes the FAA’s fleet authorization process, which depends on testing and standards work.
For an airport, the relevant unit is not the national fleet, but the aircraft it actually services. A traffic count does not answer how many based airplanes can use UL94, how many still need a particular fuel, how many owners will obtain an STC, or how transient pilots will know which pump is appropriate. Those answers, the guide says, will have to come from aircraft surveys, N-number checks, engine information, STC status and fuel-use estimates.
The guide also puts attention on unleaded avgas standards and compatibility. Mogas and UL94 are covered by ASTM standards. G100UL had no ASTM standard at the time covered by the report. Swift 100R had an ASTM standard in development. Those details may affect how airports, fuel providers, insurers and aircraft owners evaluate misfueling risk, product acceptance and infrastructure decisions.
The Checklist Is The Work
The National Academies material includes five tools for airports as they make the unleaded avgas transition. These include a transition checklist, separate survey forms for individual-aircraft owners and multi-aircraft operators, a fleet inventory spreadsheet and a fuel cost evaluation tool. Together, they are intended to give airports a way to track the process, estimate which aircraft can use available unleaded fuels, evaluate demand and compare the costs of possible transition paths.
The guide draws on case studies from seven airports that had begun, or were preparing for, unleaded avgas service while continuing to offer 100LL. It also includes material related to Alaska, where seasonal fuel delivery, storage limits, remote communities and reliance on piston aircraft create a different transition problem from the one faced by many airports in the lower 48.
Aircraft owners will face their own set of questions around unleaded avgas that the guide addresses only in part. It discusses fuel approval paths, STC requirements, compatibility, standards, price differences and some cost considerations, mainly as they affect airport planning. It does not settle what pilots will encounter in daily use, including long-term fuel availability, final pricing, warranty and insurance treatment, resale effects, or the fate of aircraft that may be legal to convert but difficult to justify economically. The FAA’s draft plan raised many of those issues without closing them, and since the final plan has not yet been released, we still do not have a final, authoritative answer on how these will be addressed.
The ACRP guide is strongest where it stays on airport work. It gives operators a way to survey the local fleet, evaluate tankage, train line staff and reduce misfueling risk. Those steps are necessary, although the guide has limited answers for airports with one avgas tank, uncertain transient demand, competing unleaded avgas products, unresolved production capacity or local economics that do not support adding another fuel grade. Its tools can help an airport organize the problem, but they cannot remove the market and regulatory gaps that will determine whether a local plan is workable.
The final FAA transition plan will still matter greatly, and so will the comments the agency received and plans to summarize later this year. Production capacity, price, distribution, fuel standards and aircraft eligibility will shape the pace of change. The ACRP publications do not answer every national question, but of course, they do not claim to. Rather, they describe the work that airports can begin while those questions remain open.
And that is where the unleaded avgas transition now sits. The policy deadline remains 2030 and the final federal plan is still pending as quite a few very practical questions remain unanswered.
Even so, the burden is already moving to the ramp, the fuel farm and the airport office, where the future of piston fuel will be managed through local decisions that have to keep aircraft flying while the fuel supply changes beneath them.
If these decisions around unleaded avgas will have any impact on your flying — and they almost certainly will if you’ve read this far — you would be well advised to become or remain as heavily involved in your local airports’ decision making processes as you can. The choices made at that level will almost certainly decide what goes into your tanks just a few short years from now, if not sooner.
Matt Ryan
  1. (The National Academies put the unleaded fuel transition in the hands of airport operators.) Really
    The FAA with backing from the AOPA has created a 100LL fuel mandate that actually takes the unleaded fuel transition out of the hands of the US airport operators by tell them what fuel they have to sell like it or not. In Europe airport operators are free to give up 100LL without the government taking legal action against them and so some have dropped 100LL completely without government cutting their funds. Normally in Europe they make an alternative unleaded fuel available. Normally it is an auto fuel without ethanol or an ASTM approved UL 91 that most aircraft can us without an STC.
    Airport operators have been denied this freedom by the FAA in cooperation with the AOPA in the USA.
    The FAA could do a fleet authorization for ASTM approved UL 91 as they had promised they would do several years ago. Anybody that has ever dealt with the FAA knows this government agency is not designed to be helpful and never does anything in a timely manner.
    The FAA asked people to respond to the unleaded fuel situation and I did that. Where are the results from that? It seems we’re hearing nothing from them.
