Live ATC Audio from Oshkosh ’99
  • The article offers live ATC audio streaming directly from Oshkosh (AirVenture), covering the Oshkosh tower frequencies and the "Fisk Approach" frequency.
  • Due to high demand and limited simultaneous streams, each user is restricted to five minutes of listening time.
  • Users need to download and install RealPlayer G2 to access the streaming RealAudio feeds.
AVweb at AirVenture
Live ATC Audio
from Oshkosh!
RealAudio
Aerial view of AirVenture at OshkoshWehope you enjoy our live ATC streaming audio feed straight from Oshkosh. What you’relistening to is the output of a air-band scanner which scans among the two Oshkosh towerfrequencies and the “Fisk Approach” frequency.
Because we can serve a limited number of simultaneous audiostreams, and because the demand to listen to these streams is so high, each user is limited to five minutes of listening time,after which the audio feed will be interrupted. If all streams are in use, you’ll get anerror message…in that case, please try again in a few minutes.
RealPlayer G2To listen to this and ourother streaming RealAudio feeds, you’ll need a copy of  RealPlayer G2, which you candownload free from https://www.real.com.
OSH NOTAM
OSH Arrival Procedures
