This section of AVweb’s exclusive AirVenture 2001 coverage brings you even closer to the daily action at this year’s show. Using a free, low-bandwidthRealPlayer and our streaming RealAudio feeds, you can hear all the calls from ATC at EAA’s AirVenture 2001. Also check out other sections of our audio coverage like:
Because we can serve a limited number of simultaneous audio streams, and because the demand to listen to these streams is so high,eachuser is limited to 15 minutes of listening time, after which the audio feed will be interrupted. If all streams are in use, you’ll get an error message…in that case, please try again in a few minutes.
While you’re listening, we suggest you explore AVweb’s daily AirVenture 2001 newscoverage and famous AirVenture photo gallery. ![]() ![]() |
Oshkosh 2001 Complete Audio Coverage (Including Live ATC!)
- AVweb offers exclusive live streaming audio coverage of AirVenture 2001, including Air Traffic Control (ATC) communications from Oshkosh tower and Fisk Approach frequencies.
- Beyond live ATC, the audio coverage features daily airshow events from WOSH radio, "OSHtalk" hangar flying sessions with aviators and experts, and the "Meet the Administrator" session with FAA Administrator Jane Garvey.
- Access to these RealAudio streams requires a free RealPlayer G2 and is limited to 15 minutes per user due to high demand and restricted server capacity.
We hope you enjoy our live ATC streaming audio feed straight from Oshkosh. What you’re listening to is the output of a air-band scanner which scans among the two Oshkosh tower frequencies and the “Fisk Approach” frequency.
