777X Test Fleet Grounded
  • Boeing has suspended certification flight testing for its new 777X airliner.
  • The suspension is due to discovered problems with the engine attachments, specifically a broken thrust link on one test aircraft and cracks on the thrust links of the other two, affecting the entire test fleet.
  • Boeing confirmed the issue, stating a component "did not perform as designed" and will resume testing after replacements are made.
  • This incident marks another setback for Boeing, which has recently faced other manufacturing and quality control challenges, with the duration of the fix currently unclear.
The Air Current is reporting that Boeing has suspended certification flight testing of its new flagship 777X airliner after it found problems with the engine attachments in all three test aircraft. The publication said a thrust link that helps secure the engine to its mounting structure was discovered to be broken after a flight from Kona, Hawaii, to Seattle. Cracks in the thrust links on the other two aircraft were also discovered, prompting the grounding of the fleet.
The Air Current said Boeing confirmed the testing pause, saying it “identified a component that did not perform as designed” and that after replacement the company “will resume flight testing when ready.” After a series of manufacturing and quality control issues, the announcement of certification flight testing of the new 777 variant was viewed as a ray of sunshine for the troubled company. It’s not clear how long it will take to fix. Thrust links help distribute loads within the mounting structure of the engine.
