Air India Final Report Expected To Be Delayed
Engine analysis remains underway ahead of Friday’s one-year anniversary.
Air India Accident Report Expected To Be Delayed
[Credit: Ryan Fletcher | Shutterstock]
  • India's final report on the Air India Flight 171 crash (June 12, 2025), which killed 241 of 242 on board and 19 on the ground, is delayed past its one-year anniversary due to ongoing analysis of its GE Aerospace GEnx engines.
  • Preliminary findings indicated that both engine fuel control switches moved from "run" to "cutoff" shortly after takeoff, an action pilots denied, leading to engine issues before attempts to restore power.
  • The investigation includes examining the engine management unit and a 2018 FAA advisory bulletin about potential fuel control switch locking feature disengagement, which Air India had not completed as the inspections were not mandatory.
India’s final report on the Air India Flight 171 accident is expected to be delayed beyond Friday’s one-year anniversary. A source familiar with the investigation told Reuters Thursday that investigators are still completing analysis of the aircraft’s GE Aerospace GEnx engines. International accident investigation rules call for a final report within a year when possible. If that is not possible, an interim statement is issued on the anniversary.
The Air India Boeing 787-8 was operating from Ahmedabad to London Gatwick on June 12, 2025, when it crashed shortly after takeoff. The accident killed 241 of the 242 people on board, along with additional 19 people on the ground.
In its preliminary report, India’s Aircraft Accident Investigation Bureau said the aircraft took off at 08:08:39 UTC and reached a maximum recorded airspeed of 180 knots before both engine fuel control switches moved from run to cutoff about one second apart. The report said the cockpit voice recording captured one pilot asking the other about the cutoff, and the other pilot saying he had not done it.
The preliminary report said the switches were later moved back to run. One engine began to recover, while the other relit but did not recover before the recorder stopped.
Investigators conducted engine testing in April and traveled to France last month as part of analysis of the engine management unit. The AAIB preliminary report also noted a 2018 FAA Special Airworthiness Information Bulletin on the possible disengagement of the fuel control switch locking feature. The bulletin was advisory, and AAIB said Air India reported the suggested inspections had not been completed because they were not mandatory.
Air India later said it completed precautionary inspections of the fuel control switch locking mechanisms on its Boeing 787 and 737 fleets and found no issues, according to Reuters.
Matt Ryan
  1. Avatar for RonB RonB says:
    I’d like to hear an explanation of Air India pilot duties during takeoff/climb. If the cockpit procedures required the pilot-not-flying to guard the throttles on takeoff, I still contend that the PNF may have inadvertently cut off the engines by removing his hands from behind the throttles and back across and above the Fuel Control switches. Perhaps a jacket sleeve, bracelet, or wristwatch snagged the switches. The “lever-lock” detent for that type of switch could be inadvertently defeated by should action.
  2. While I’m not familiar with those exact switches, having flown the 757 and 767, the Boeing switches are generally quite robust. It takes a positive ‘lift’ of the switch to make them move. Truly doubt brush of the hand would do it
  3. If they try and blame the pilot without any evidence, there will be an outcry. About time cockpit video mandatory.
  4. Read Scott’s description of switches on 757/767.
    Would have to be very careless.
    Or fundamental brain confusion.
  5. Was it possible for incorrect rote memory to flip fuel cutoff switches when another set of switches or levers was supposed to be selected in the adjacent area?
  6. One of the pilots moved the switches to stop, after they started to shut down he moved them back to run, knowing there would not be time for a complete re-light and spool up, confusing the investigation. Has India released the complete background of the pilots?
  7. Avatar for vince vince says:
    Sure sounds like a deliberate act.
