ADs Affect Cessna, Piper Fleets
  • The FAA issued two Airworthiness Directives (ADs) for general aviation aircraft, targeting Cessna and Piper models.
  • A Cessna AD affects about 5,000 twin-engine T310Q, 310Q, and 402B aircraft, requiring replacement of elevator trim tab hardware within 90 days at a cost of approximately $100.
  • A Piper AD mandates inspection for wing-rib cracks in about 700 PA-28 Cherokees within 25 flight hours, costing around $85 for inspection and an additional $125 if repairs are needed to prevent reduced wing structural integrity.
image: Wikimedia
The FAA issued two direct-to-final-rule Airworthiness Directives today that affect general aviation airplanes. A Cessna AD addresses the elevator trim tabs in about 5,000 twin-engine T310Q, 310Q, and 402B aircraft. Textron already has issued a service bulletin, but allows up to a year to make the fix — the FAA said today it is shortening that time to 90 days. The clock starts April 26, the effective date of the AD. Replacing the elevator trim push-pull rod hardware should cost about $100, the FAA said. The Piper AD addresses reports of wing-rib cracks found in PA-28 Cherokees, and extends the directive to more models than the previous AD.
The Piper AD affects about 700 airplanes. The cost to operators should be about $85 for an inspection, and another $125 if repairs are needed, the FAA said. The cracks occurred during production, the FAA said, and if not corrected, could result in reduced structural integrity of the wing. Operators must comply with the AD within 25 hours of flying after the effective date of April 26, with the exception of those airplanes listed in the previous AD, which have 25 hours after last Oct. 29 to comply.
