NASA Flies Hybrid Electric VTOL
  • NASA has successfully performed tethered flights of its Greased Lightning, a hybrid-electric tilt-rotor concept aircraft designed for practical VTOL unmanned operation.
  • The aircraft features swiveling wings and tail surfaces to convert engines into lifting rotors, with most engines shutting down and props folding for efficient cruise flight.
  • Powered by lithium-ion batteries charged by onboard diesel engines, the Greased Lightning concept is "scale free" and can be applied to much larger aircraft designs.
NASA has flown its tilt-rotor hybrid electric concept aircraft and hopes it will result in a practical VTOL unmanned aircraft. Greased Lightning flew for the first time Aug. 19 (tethered) and it represents a new take on an old design first pioneered by Canadair in the 1950s and used by the V-22 Osprey. The wings and tail surfaces swivel, allowing the engines to be turned into lifting rotors. In Greased Lightning’s application, however, most of the engines are shut down for cruise flight and the rotors/props fold to reduce drag.
The engines are powered by a bank of high-density lithium-ion batteries that are charged in flight by a couple of 8-horsepower diesel engines driving alternators. The diesels are housed in the fuselage. Although Greased Lightning is about the size of a big RC model aircraft, NASA says the concept is “scale free,” meaning it could be used on much larger aircraft. Untethered flights are planned for later this year.
