New Instrument Panel Annunciator Aims To Reduce Gear-Up Landings
  • Approach Aviation announced FAA approval and production shipments of its FlexAlert multifunction panel annunciator, an LED display that consolidates warnings for landing gear, engine status, electrical systems, and more.
  • Certified for Part 23 aircraft as a supplemental alteration, the compact 3.0-by-1.3-inch device cuts installation time by 50% and saves over $1,000 compared to individual or customized annunciators.
  • Designed to enhance flight safety and reduce incidents such as gear-up landings by placing critical visual alerts directly in the pilot's view, the unit launches August 1, 2017, at an introductory price of $699.
At AirVenture 2017, Massachusetts-based Approach Aviation announced FAA approval and production shipment of its FlexAlert multifunction panel annunciator.
The LED display, compatible with both land and seaplanes, gives pilot warnings for engine, oil pressure, fuel pressure, low fuel, pitot heat, low voltage, over voltage, alternator failure, doors, starter engaged, vacuum failure and autopilot glideslope capture, as well as landing gear status.
Compared to competing individual or customized annunciators, Approach Aviation claims the FlexAlert multifunction annunciator can save over $1000 and 50 percent of installation time. The LED display is also significantly brighter and more reliable than a traditional incandescent lamp.
The FlexAlert multifunction annunciator measures 3.0 by 1.3 inches, making it compatible for easy retrofit in almost any panel. It is certified for Part 23 aircraft as a minor alteration, but only when used for supplemental purposes and not primary. It is configurable out of the box for both retractable and fixed-gear aircraft, and the kit includes flush panel mounting bracket options.
“The Aviation Safety Reporting System receives an average of 60 gear-up landing reports per year and one of the factors responsible for these incidents is the lack of clear visual annunciation in the pilot’s field of view,” said Approach Aviation President Jeff Simon. “The FlexAlert multifunction annunciator consolidates gear status, as well as many other critical alerts, directly in front of the pilot and with the clarity one should expect of modern avionics. It’s a great addition when upgrading ADS-B or as a standalone flight-safety enhancement.”
FlexAlert multifunction annunciators are currently being sold at the special introductory price of $699. Shipments will begin Aug. 1, 2017, and can be purchased directly from Approach Aviation at FlexAlertAero.com, or from select avionics retailers.
