EAGLE Explains PAFI Process
  • The Eliminate Aviation Gasoline Lead Emissions (EAGLE) group's latest bulletin details the Piston Aviation Fuels Initiative (PAFI) and its role in the FAA potentially issuing "fleet authorization" for new fuels, such as Lyondell/Basell's, after extensive compatibility and performance testing.
  • This "fleet authorization" process is distinct from the Supplemental Type Certificate (STC) method, which GAMI used for its universally approved G100UL fuel, and Swift for its 100R fuel with limited aircraft approvals.
The Eliminate Aviation Gasoline Lead Emissions group has issued its second in a series of three information bulletins, this one explaining the Piston Aviation Fuels Initiative (PAFI) and the role it plays in the FAA’s potential issuance of a “fleet authorization” for a fuel being developed by Lyondell/Basell. If the fuel passes the battery of compatibility and performance tests conducted at FAA labs the agency will issue a list of compatible aircraft and engines and what, if any, modifications are required for its use.
The previous bulletin dealt with the Supplemental Type Certificate process chosen by GAMI and Swift for their fuels. GAMI’s G100UL already has STCs approved for all certified airplanes and all certified aircraft engines. Swift’s 100R fuel is STC’d for Cessna 172R and 172S models only. The full text of EAGLE’s information bulletin is below.
