The National Transportation Safety Board (NTSB) is urging aircraft owners, pilots, and maintenance personnel to pay closer attention to exhaust valve condition after investigating dozens of accidents involving stuck valves and engine power losses.
In a new safety alert issued Oct. 29, the NTSB said it investigated 42 accidents between 2015 and 2025 in which a stuck valve contributed to a loss of engine power and an accident. Those events resulted in five fatalities and 12 serious injuries.
Sticking valves can disrupt the combustion cycle in reciprocating piston engines, producing severe vibration and partial power loss. Depending on where a valve becomes stuck in its guide, the condition can also bend pushrods. Deposits accumulating on the valve stem or inside the valve guide are the primary cause.
The NTSB identified several conditions that can contribute to deposit buildup, including localized engine overheating, infrequent flying and rapid engine cooling. Incorrect fuel-air mixture settings, high ambient temperatures, low-airspeed operations with reduced cooling and fuel containing high lead concentrations can also contribute.
Piston-powered helicopters and flight school aircraft may be particularly susceptible. The NTSB noted that helicopters often operate at higher engine temperatures, while training aircraft frequently spend extended periods in the traffic pattern and may operate with rich mixture settings.
The alert noted that recognizing the early symptoms can be difficult. A sticking valve may produce a rough-running engine, particularly during cold starts, along with unusually low exhaust gas temperatures (EGTs) or cylinder head temperatures (CHTs) on an individual cylinder. The symptoms can be mistaken for other engine problems, and an unexpected power loss during takeoff or landing can leave little time to diagnose the issue.
The NTSB recommends that owners follow manufacturer-recommended oil and air filter change intervals, use proper leaning procedures, and become familiar with engine-monitoring indications that could reveal valve problems.
Mechanics should also inspect engine cooling baffles and baffle strips for deterioration, use engine-monitoring data when troubleshooting rough-running engines and follow manufacturer service instructions for diagnosing and correcting stuck valves.
The complete safety alert, SA-109, is available from the NTSB website.
Remarkably the only things that haven’t doubled in price in the last few years are engine monitors. If you don’t have one, get one. It will pay for itself in easier and more accurate troubleshooting.
I have seen many exhaust valves that look much worse than that one. Guess what is the main cause of the carbon buildup. Not leaning properly and lead in the fuel. So better education and and how about getting the lead out???
I started using TCP , added to the fuel, which converts the lead-bromide to lead-phosphate, a soft material which goes out the exhaust.
It also will scavenge the existing lead from the exhaust valves.
I had another sticking exhaust valve and the TCP resolved the problem.
The biggest problem of sticking exhaust valves is leaded fuel.
Engines running on MOGAS don’t have this problem.
Just reamed the lead out of valve guides because of no compression on a cylinder.
Lead is not good for engines;
Stop the stonewalling over unleaded fuel!
My experience is that overheating cylinder heads are the first point of the chain of events. Leaded fuel has never been a factor, rather beneficial when it comes to lean running cylinders (for whatever reason). Overheating cylinders (mostly due to running too lean - not by lack of cooling air) mean the design clearances of the moving parts are not met anymore. Things are getting tight… Also, the exhaust valve is in a stream of hotter than expected gasses. Now the problems begin. Oil is coking, stem is gumming up in the guide, the valve lags and soon sticks. You feel it with rough running on a fixed pitch prop 4 cylinder engine. It just runs badly, and lacks power. On a six cylinder 300 hp monster, combined with a constant speed prop, you won’t feel any of this. Therefore an indication of EGT’s is a necessity for such engines. But a cool head saves stuck valves.
RUN LEAN OF PEAK, IDLE LEAN and avoid handling a highly neurotoxic chemical.
I’ve been doing it for 20 years, never a stuck valve, cylinder is absolutely clean as a whistle. Also pop cap every flight to vent and use camguard. 20 years of SR22 flying in two planes costs very little to do this and avoid problems.
