AVweb’sGeneral Aviation Accident Bulletinis taken from the pages of our sister publication,Aviation Safetymagazine, and is published twice a month. All the reports listed here are preliminary and include only initial factual findings about crashes. You can learn more about the final probable cause in the NTSB’s website atwww.ntsb.gov. Final reports appear about a year after the accident, although some take longer. Find out more aboutAviation Safetyatwww.aviationsafetymagazine.com.
December 6, 2017, Chesterfield, Mo.
Beech B36TC Turbocharged Bonanza
The airplane impacted a gas station pump canopy and parking lot at 1454 Central time, following a reported loss of engine power while on a visual approach. The solo private pilot sustained fatal injuries; the airplane was destroyed by post-impact fire. Visual conditions prevailed; the flight was conducted on an IFR flight plan. According to preliminary information, the airplane was on a left-traffic visual approach when the pilot reported losing power. The local controller immediately cleared the pilot to land but he responded that he may not be able to make it to the airport. No further communications were received from the pilot. Witnesses observed the airplane at a low altitude with no engine noise. Shortly thereafter, the airplane impacted the gas station and a post-impact fire ensued. Witnesses attempted to suppress the fire with available fire extinguishers but were unsuccessful due to the intense heat and smoke.
December 7, 2017, St. Croix, V.I.
Beech 58 Baron
At about 2100 Atlantic time, the airplane was destroyed after it impacted terrain while attempting to return to the airport shortly after takeoff. The private pilot and four passengers were fatally injured. Visual conditions prevailed. Shortly after takeoff, the pilot reported to ATC, “the engines are not running right,” and requested to return to the airport. The controller instructed the pilot to fly north and cleared the airplane to land on Runway 10. There were no further communications with the pilot. The airplane came to rest on flat terrain, about 380 feet from the Runway 10 threshold and about 60 feet right of the extended runway centerline. The airplane was destroyed by impact forces and consumed by fire. Examination revealed a hole in the top forward portion of the left engine crankcase and connecting rods 4, 5, and 6 were broken. The left engine’s propeller blades appeared to be in the feathered position.
December 7, 2017, Auburn, Wash.
Cessna 172D Skyhawk
The airplane experienced a loss of aileron control during landing at about 1600 Pacific time. The solo private pilot was not injured but the airplane sustained substantial damage to its right wing and fuselage. Visual conditions prevailed. The pilot later reported the airplane’s nose veered sharply left without any control input after turning final for Runway 16. The pilot counteracted the movement by applying right rudder and the airplane veered to the right as he noticed that he had no response from aileron control input. The pilot tried to stabilize the airplane with rudder and aborted the landing by applying power. As power was applied, however, the lack of aileron response became more pronounced. He decided to reduce throttle and land. Subsequently the airplane landed on the runway surface about 45 degrees off the runway heading, exited the right side of the runway and impacted a water retention pond.
December 8, 2017, Geneva, Fla.
Beech C90 King Air
At about 1115 Eastern time, the airplane was destroyed when it impacted a lake. The flight instructor and two commercial pilots receiving instruction were fatally injured. Instrument and visual conditions prevailed in the area. An IFR flight plan was in effect. Preliminary information revealed the flight conducted a practice instrument approach to Runway 9 and executed a go-around. Controllers changed the active runway to 27R and vectored the flight for a practice ILS to it. About two minutes after the flight was cleared for the approach, the controller issued a low altitude alert and advised the flight to climb to 1,600 feet. Following a second low altitude alert with instructions to immediately climb to 1,600 feet, the flight responded, “I am sir, I am.” Shortly afterward, radar and radio contact with the accident airplane were lost. A witness observed the airplane below the cloud ceiling at 250 to 300 feet agl, then it climbed rapidly. The witness then observed the airplane dive vertically into the lake.
December 9, 2017, Algona, Iowa
Cessna 172C Skyhawk
The airplane collided with a ditch at about 0945 Central time during a forced landing after a complete loss of engine power during initial climb. The flight instructor, student pilot and passenger were not injured; the airplane sustained
substantial damage. Visual conditions existed. The student pilot was flying during takeoff. When the airplane reached 1,800 feet MSL, the student pilot began a left turn on course. Shortly after the turn, the engine went silent and stopped producing power. The flight instructor took control, slowed the airplane and landed into the wind on a gravel road. During the landing roll, the left wheel caught the edge of the road and the airplane veered into the ditch, which resulted in substantial damage to the wing and fuselage. Examination revealed the No. 1 cylinder head had separated at the cylinder-head-to-barrel interface.
This article originally appeared in the September 2018 issue ofAviation Safetymagazine.
