Short Final
  • An experimental home-built aircraft experienced a dramatic ground loop off the runway during its initial takeoff attempt.
  • The pilot, claiming no damage, requested to try again immediately after returning to the runway.
  • Air traffic control insisted on a runway inspection, while another pilot humorously commented on the first pilot's likely fear.
Family and friends were watching the first takeoff of an experimental home built.As he came down the runway he over pitched then pushed the nose down hitting the runway causing a ground loop off the runway with dirt flying. He then taxied back on the runway.
Tower: “What are your intentions?”
He said there was no damage and would like to go again.
Tower: “We will have to check the runway to be sure its clean first.”
Pilot in pattern: “And he’d better check his pants to make sure they are clean.”
Name Withheld
