Electrical Ground Issue Grounds Dozens Of MAXes
  • Boeing has instructed 16 airlines to ground some 737 MAX aircraft globally, including specific numbers for Southwest, American, and United, due to a potential manufacturing fault in the electrical system's ground connection.
  • Airlines must inspect the affected planes, a process taking a few hours, and fix them if necessary, which could keep an aircraft out of service for a few days.
  • The identified fault is isolated to the electrical system, not related to flight controls, and while no issues have been reported, this is the first time the 737 MAX has been grounded since its return to service.
Boeing has told 16 airlines to ground some Boeing 737 MAXes until they confirm a proper ground connection on part of the electrical system after discovering a potential manufacturing fault. Dozens of aircraft all over the world are affected. Southwest pulled 30 from service, American 17 and United 16. None of the airlines has reported any issues because of the potential fault, which is isolated to one part of the electrical system. It is not related to the flight control system.
The airlines have been told to inspect the planes and check the ground and fix it if necessary. The inspection only takes a few hours but if it needs to be fixed the plane could be out of service for a few days. There have been several maintenance bulletins on the type since its return to service after a two-year grounding earlier this year but the first that took the planes out of service.
