FAA Proposes Emergency AD For Lycoming Rods
  • The FAA has proposed an emergency Airworthiness Directive (AD) for Lycoming engines overhauled between 2015 and 2016 to address off-spec connecting rod small-end bushings.
  • This AD codifies Lycoming's Mandatory Service Bulletin 632 and is being expedited due to serious safety concerns, bypassing the usual commenting period.
  • The AD affects an estimated 778 U.S. airplanes, with costs ranging from $1,425 for inspection to over $6,000 if part replacement is required.
The FAA Wednesday evening proposed an emergency airworthiness directive requiring owners of Lycoming engines to inspect and potentially replace off-spec connecting rod small-end bushings in Lycoming engines overhauled during the 2015 to 2016 time period. The AD codifies the procedures found in Lycoming’s Mandatory Service Bulletin SB 632 released last month.
Although Lycoming says at least 1300 of its own engines are affected by the SB and now AD, the FAA AD language says 778 airplanes on the U.S. registry are covered. The FAA estimates the total cost of the AD to U.S. owners to be $1.1 million or about $1425 per engine if no replacements are required. If connecting rod replacement or bushing replacement is required, the cost ranges from $2170 for four-cylinder engines to $6680 for six-cylinder engines. The FAA said it believes the bushing issue represents a serious enough safety hazard to short-circuit the usual commenting period for ADs. Here’s the proposed text of the AD. As of Wednesday, it was unclear how many of the named engines are Lycoming factory engines and how many are field shop engines. For more, see Lycoming’s FAQ on SB 632.
