EAA Addresses G100UL Use In E-AB Aircraft
Credit: GAMI
  • The Experimental Aircraft Association (EAA) expressed concerns about the use of G100UL unleaded aviation gasoline in Experimental-Amateur Built (E-AB) aircraft.
  • EAA emphasizes that Supplemental Type Certificates (STCs) for G100UL only apply to type-certificated aircraft, not E-AB aircraft, raising safety concerns due to potential material incompatibilities.
  • EAA highlights potential issues with fuel system components in E-AB aircraft, including sealants, gaskets, O-rings, and hoses, which may not be compatible with G100UL.
  • EAA encourages E-AB aircraft owners to review GAMI's provided information on G100UL installation, airworthiness, and refueling hygiene before use.
Last week, the Experimental Aircraft Association (EAA) weighed in on the controversy surrounding G100UL unleaded aviation gasoline from General Aviation Modifications Inc. (GAMI). As an advocacy group for Experimental-Amateur Built (E-AB) aircraft, among others, EAA’s statement focused on specific concerns for E-AB builders and operators.
While EAA noted that G100UL has been authorized for use in “most certified aircraft” through the Approved Model List Supplemental Type Certificate (AML STC) process, EAA reminded its members, “It is important for owners of E-AB aircraft to remember that STCs only apply to type-certificated aircraft. E-AB aircraft do not have type certificates and, thereby, are not covered by an STC.” The statement also noted that some materials used in E-AB aircraft are different from those found on certified aircraft and it’s possible those materials were not considered in granting the STC. “Testing protocols for STCs are proprietary, and to date a list of materials tested has not been shared with owners and operators,” EAA wrote.
Among the components cited by EAA as of concern are fuel tank sealants, gaskets, O-rings and hoses as well as any other materials that could come into contact with the fuel either through normal operation or in the event of a spill or leakage.
EAA provided links to information made available from GAMI on installation instructions, instructions for continued airworthiness and routine refueling hygiene.
Mark Phelps
