NBAA Raises Concerns Over ADS-B Security
  • The NBAA (National Business Aviation Association) argues that the FAA's ADS-B plans compromise operators' privacy, security, and business competitiveness.
  • The concern arises because ADS-B transmits unencrypted, real-time flight data (like call sign, position, and speed) that can be easily intercepted, potentially allowing competitors to track business movements.
  • NBAA previously advocated successfully against a similar FAA policy in 2011 and plans to continue advocating for changes to protect general aviation privacy and security, despite the upcoming ADS-B Out mandate.
The FAA’s plans regarding ADS-B, or automatic dependent surveillance-broadcast services, don’t offer enough protection for operators’ privacy, security and business competitiveness, NBAA President Ed Bolen said in an op-ed this week. “ADS-B transmits an unencrypted, real-time signal that includes the aircraft’s Mode S transponder code, its call sign, aircraft type, position and airspeed, as determined by the aircraft’s own GPS-based avionics,” Bolen wrote. “Anyone with the right equipment can capture that real-time data and potentially use it for nefarious purposes.” Bolen said NBAA is concerned that its members’ flights could be tracked by competitors trying to deduce their next business moves.
NBAA and other advocates prevailed in 2011 when they raised similar concerns about an FAA policy that would have made flight data public without the option for operators to block it. “We believe people should not have to surrender their security or privacy just because they board a general-aviation airplane,” Bolen wrote. NBAA will continue to monitor the situation with regard to ADS-B and will advocate for change. ADS-B is a cornerstone of NextGen air traffic modernization, and the FAA has mandated that aircraft operating in airspace that now requires a Mode C transponder must be equipped with ADS-B Out by Jan. 1, 2020.
