FAA Extends Aircraft Re-Registration Period
  • The FAA is extending the registration interval for all general aviation (GA) aircraft to seven years via a new Direct Final Rule.
  • This change is a result of a 2018 congressional mandate for non-commercial aircraft, which the FAA broadened to cover all GA aircraft due to the impracticality of distinguishing commercial from private use by aircraft type.
  • The new seven-year term replaces the previous three-year registration limit, which was implemented in 2010 to address inaccurate "ghost registrations" after lifetime registrations proved problematic and was considered too onerous for private operators.
The FAA will issue a Direct Final Rule extending the registration interval for general aviation aircraft and the new seven-year duration applies to all GA aircraft. Until 2010, aircraft registrations lasted for the life of the aircraft but that resulted in a lot of inaccurate and ghost registrations on the books. In 2010, the agency made all operators re-register their planes and set a three-year limit for re-registration. The alphabets argued that was too onerous for private operators and got the ear of Congress. The 2018 FAA reauthorization mandated the agency extend the limit to seven years for non-commercial aircraft.
That caused an issue for the FAA because use and not aircraft type defines the distinction between commercial and private operation. “Consequently, it is impracticable to have different durations for commercial and noncommercial general aviation aircraft registrations,” the final rule says. “Therefore, the FAA is extending the registration duration for all aircraft to seven years.” As before, re-registration has to take place by the end of the month of the anniversary of the existing registration.
