FAA Says: Replace Old Mufflers
  • The FAA issued a non-mandatory bulletin recommending that aircraft mufflers on reciprocating engines be replaced after 1,000 hours of service to prevent carbon monoxide (CO) poisoning in the cockpit.
  • A Wichita State University study revealed mufflers are the leading source of CO in related accidents, with 92 percent of those mufflers having been in service for over 1,000 hours.
  • Diesel engines are exempt from the guidance due to low CO production, and the FAA recommends pilots install electrochemical CO detectors on the instrument panel.
If the muffler on your reciprocating aircraft engine is more than 1,000 hours old, you should replace it to help minimize the chance of getting carbon monoxide in the cockpit, according to a Special Airworthiness Information Bulletin released by the FAA. The recommendation is not mandatory. The FAA based its suggestion on the results of a technical study by Wichita (Kans.) State University that was completed last year. The researchers surveyed accident data from the NTSB and found that when CO was a factor, the muffler system was the top source. In 92 percent of the muffler-related accidents, the muffler had been in service for more than 1,000 hours. Diesel-powered engines are not affected by this recommendation, Centurion Aircraft Engines said this week, because that combustion process produces hardly any excess CO.
The next revision of the FAA’s SAIB will make note of the fact that diesel engines are exempt, Centurion said. The FAA bulletin also noted that pilots should use CO detectors in the cockpit. The Wichita study, which is posted online (PDF), found that electrochemical sensor-based CO detectors were the most effective of the commonly used detectors and the instrument panel was the most effective location.
