A380 Flies On Cooking Oil
  • Airbus successfully test-flew its A380 using one engine powered by 100% Sustainable Aviation Fuel (SAF) derived from used cooking oil and waste fats.
  • This A380 flight is the third Airbus aircraft type to fly on SAF, following earlier tests with A319 and A350 models.
  • Airbus aims for net-zero emission jets by 2035, and the same A380 testbed will also be used for future hydrogen-powered engine development.
A lot of french fries went into Airbus’ latest sustainability photo op. The planemaker flew its first flight test A380 with one engine burning 100 percent sustainable aviation fuel (SAF) made from used cooking oil and other waste fats on two flights last Friday and Monday, putting more than five hours on the carbon neutral clock. “The flight test met all of our requirements, which will enable us to carry out the next phase of the project consisting of specific engine maneuvers,” Airbus test pilot Wolfgang Absmeier said.
The A380 was the third aircraft Airbus has flown on SAF. It earlier used an A319 and an A350 to try it out. All Airbus jets can use up to 50 percent SAF now and the company hopes to have net zero emission jets by 2035. It’s also not finished with that well-used A380 test article. That same first-off-the-line airframe will become the test bed for a hydrogen powered engine. Last December, United Airlines used 100 percent SAF to power one of the engines on a Boeing 737 on a revenue flight.
