Boeing Awarded Advanced Aircraft Research Grants
  • Boeing secured $425 million from NASA to develop a full-scale single-aisle airliner prototype featuring a "transonic truss-braced wing" design, aiming for 30% greater fuel efficiency.
  • Boeing's Aurora Flight Sciences received $42.4 million from DARPA to create the CRANE prototype, a fighter-sized aircraft that navigates using "active flow control" (strategically aimed air jets) instead of traditional movable control surfaces, with potential benefits for drag reduction, weight, and stealth.
Boeing attracted almost half a billion dollars in government research money this week with two projects that challenge contemporary aircraft design. NASA announced it will cover $425 million of the $725 million cost of building a full-scale prototype single-aisle airliner with strut-supported glider-like wings. Boeing and its partners will pay the balance. The projection is that the “transonic truss-braced wing” demonstrator will use 30 percent fuel than a conventional single-aisle airliner. If all goes well, the planes could be in service in a decade or so.
Boeing’s Aurora Flight Sciences is getting $42.4 million from the Defense Advanced Research Projects Agency (DARPA) to build a full-scale fighter-sized plane that has no movable control services. Instead, the Control of Revolutionary Aircraft with Novel Effectors (CRANE) prototype will navigate the three axes by using strategically aimed jets of air into the slipstream flowing over the aircraft surface. This “active flow control” has the potential to reduce drag and weight, but DARPA is likely also interested in the implication for stealth designs. DARPA is covering the whole cost of the project.
