Could Automotive Lane-Deviation Tech Help Combat Pilot Disorientation?
Haptic vibration could be an aid in preventing loss of control accidents.
Maryland professor and student helicopter pilot Anubhav Datta tries on experimental wearable anti-disorientation gear. (Screenshot from CBS News report)
  • University of Maryland researchers are developing haptic technology to combat spatial disorientation in pilots, a significant and often fatal cause of general aviation accidents.
  • Inspired by automotive lane-deviation warnings, this technology aims to provide pilots with subtle vibrational cues via a flight suit or seat to help them intuitively correct their orientation, particularly in low-visibility conditions.
  • The system would introduce an additional sensory input to resolve conflicts between instrument readings and a pilot's perceived equilibrium, with plans to advance to actual flight testing.
A team at the University of Maryland is exploring the same technology used in automotive lane-deviation warnings in hopes it could help cut down on spatial disorientation in pilots. FAA statistics show that between 5% and 10% of all general aviation accidents involve spatial disorientation and that 90% of those accidents are fatal.
As outlined in a CBS News report, the Maryland researchers are exploring whether using haptic vibration could cue pilots they are losing spatial orientation, particularly in zero-visibility conditions. Maryland professor Anubhav Datta, who is learning to fly helicopters, said, “It happens when you fly into clouds or bad weather, but especially for helicopters, [in which] you can fly at zero speed. Just going up and down, it’s easy to get disoriented.” Former NTSB chairman and current CBS News transportation safety expert and analyst Robert Sumwalt added, “Spatial disorientation is a big deal in aviation and it’s basically where the pilot cannot determine which way is up or down or whether the airplane is banking to the left or to the right.”
The University of Maryland team is exploring the possibility of developing a flight suit or even a pilot’s seat that would deliver subtle but positive haptic vibrational cues to enable the pilot to intuitively correct for spatial disorientation. Project lead professor Umberto Saetti said, “The pilots typically fly through two primary sensor cues, which are vision and equilibrium. Basically, the suit provides another sensory cue to [help] deconflict the conflicts that may arise from reading their instruments and whatever the pilot is feeling.”
The University of Maryland research team ultimately intends to bring the research to actual flight testing for the technology.
Mark Phelps
  1. Explored all of this technology many years ago for Army rotary wing aviators. Requirement surfaced back when aircrews were browning out in the desert during landing and crashing. Also an occasional inadvertent flight into IMC that would end badly. Feedback from the test subjects on the haptics was mixed, cost to benefit ratio too high. What they really wanted was a virtual horizon and moving map depiction of the terrain and horizon delivered via Helmet-Mounted Display, so we did that. Overwhelmingly positive feedback, and although not cheap, cost to acquire and install was not unreasonable. Biggest technical challenge was the terrain and obstacle symbology delivered to the eye was generated from a static database (e.g. no real time imaging sensors). So how to depict a tower or that single power line someone draped across the creek since the last database update, but that wouldn’t be an issue for your typical fixed wing GA pilot. Biggest sustainment cost driver was subscribing to the map updates and keeping up with physically loading the updates into the symbol generator in the aircraft. Between those challenges and the belief that training could solve the problem the system never went to production.
  2. I appreciate you adding the detail. When I read this I remembered this was tested by the military years ago.
  3. Autopilot technology is far more likely to be the answer to fixing this problem than haptics. Autonomy has pushed autopilot capability to having Autoland functionality in several GA aircraft. Even my low-end RV-12 has a LEVEL button on the autopilot that will keep the aircraft upright if I lose SA. Soon enough we will have autopilot’s with full envelope protection with control servos that push back on the stick/yoke if you try to do something stupid that will crash the aircraft.
  4. What ever happened to the duck and the dog?
  5. Thankyou for that background.
    I expect cost would be lower today, and imaging sensors are available.
    Inadvertent flight into IMC is a problem for GA pilots, ‘scud running’ is an old term for trying to stay under clouds flying lower than is safe. And accident flying Calgary AB to Salmon Arm BC comes to mind, IIRC pilot familiar with the route.
    (BC is full of high rocks, a COPA convention in Red Deer AB featured mountain flying seminars and a demonstration loop into foothills.)
  6. The posts about the new ‘Level’ button on the autopilot is a much more cost effective way to implement SA protection. However, pilots have to USE it. All Cirrus aircraft are equipped with a whole aircraft parachute, yet many Cirrus aircraft crash, killing the occupants, because the pilot did not want to pull the chute.
    Putting the haptics in the seat or a suit would be cost prohibitive for most/all GA aircraft. Putting it in the control yoke would be better, but again, pilots have to use and respond to the input. Modern avionics have fantastic displays right in front of the pilot. Again, the pilot must be competent in using and interpreting these displays. Currency does not equal competency. IFR currency is 6 approaches, hold, tracking a course in 6 months; that does not equate competency.
    Haptics may sound good, but even stick shakers have proven ineffective ( think Colgan). More emphasis on SA in flight reviews, IPC’s, and the like would go much further.
  7. Actually that already exists in the Garmin GFC 500 autopilot, and probably others with envelop protection as well. If you get to the edge of the envelop the machine does push you back.
  8. Both Honeywell and Garmin provide Envelope Protection which vibrate/shake the control column when going past 60 deg angle of bank.
  9. Haptic may be ok, but all a vibration REALLY does is “somethings wrong”, leaving it up to the wetware to figure out why it’s getting a vibration.
    Late model autos do this ad-nauseum. With all the tech available, auto makers cannot seem to figure out how to communicate IN WRITING what the problem is. Just “somethings wrong puny human”.
    I hope the aviation world can figure out how to provide useful data to the wetware
  10. Wakes you up anyway, in some situations that’s what is needed.
    Yes, car makers are 2yos, confusing chimes and door locks in 2009 Chevrolet HHR for example.
    (Give a 2 year old child a hammer and everything becomes a nail, they understand action but not purpose and focus.)
