FAA Clears Key Step for ZeroAvia Electric Engine
Publication of special conditions marks important certification step for electric regional propulsion system.
[Credit: ZeroAvia]
  • The FAA has published final special conditions for ZeroAvia's ZA601 electric engine, establishing additional safety standards crucial for its type-certification process.
  • These special conditions were deemed necessary because the electric engine's novel design features, such as its motor and high-voltage electrical system, are not fully addressed by existing airworthiness standards developed for traditional turbine and reciprocating engines.
  • The new standards aim to provide an equivalent level of safety, covering areas like fire protection, overspeed, and electrical system safety, marking a significant milestone for ZeroAvia's hydrogen-electric powertrain intended for commercial aircraft.
The FAA earlier this month published final special conditions for ZeroAvia’s ZA601 electric engine, establishing additional safety standards for the company’s 600-kW propulsion system as it moves through the type-certification process. The rule is part of the certification path for the electric propulsion system that the company plans to use in its ZA600 hydrogen-electric powertrain for 10- to 20-seat commercial aircraft.
The FAA said the engine’s electric motor, controller and high-voltage electrical system represent a “novel or unusual design feature” not fully addressed by existing airworthiness standards for aircraft engines.
The FAA said the special conditions are needed because current Part 33 engine standards were developed around turbine and reciprocating engines rather than electric propulsion systems. The final rule applies to ZeroAvia’s Model ZA601 electric engine and took effect March 18.
In addition to requirements covering ratings, operating limits and durability, the special conditions address areas including fire protection, overspeed, control systems, vibration, ingestion, containment and electrical system safety. The FAA said the standards are intended to provide “a level of safety equivalent to that established by the existing airworthiness standards.” The agency also noted that no comments were received after the proposed special conditions were published in January.
“Having special conditions for our electric propulsion system published by the FAA is an enormous achievement that underscores the aerospace maturity of our organization and illuminates our path forwards towards type certification,” founder and CEO Val Miftakhov said.
ZeroAvia said the electric propulsion system combines its motor and inverter technology and is intended to work with the company’s fuel-cell modules as part of its hydrogen-electric powertrain.
Matt Ryan
  1. Come on, what’s the HP of this electric engine?
