Investigation Details February Growler Crash
Report cites runway conditions and human error.
Investigation Details February EA-18G Growler Crash
[Credit: U.S. Navy photo by Mass Communication Specialist 2nd Class Clifford L. H. Davis]
  • A U.S. Navy EA-18G Growler crashed into San Diego Bay after its crew safely ejected, with the crewless jet then climbing to approximately 8,000 feet before stalling and going down.
  • The crash followed a challenging landing attempt on a wet runway with a tailwind, compounded by previous fuel leak issues with the aircraft and the pilot noting "mushy" brakes.
  • A Navy investigation attributed the mishap to human error combined with adverse weather conditions, specifically citing the inability to safely stop due to wet runway and tailwind, and the failure to use maximum braking techniques.
A U.S. Navy EA-18G Growler that crashed into San Diego Bay in February climbed to about 8,000 feet after its crew ejected, according to documents from a recently completed Navy investigation.
The two-seat attack jet went down near Shelter Island following a failed landing attempt at Naval Air Station North Island, coming down within close proximity to homes, hotels and restaurants. Both crew members ejected safely and were rescued from the water within minutes.
According to the investigation records first reported by ABC 10News San Diego, the crew switched to a spare aircraft earlier in the day because of a fuel leak and later encountered separate leakage issues before deciding to return to base. The pilot told investigators he was advised of water on the runway and landed with a tailwind and higher-than-normal speed.
After applying the brakes, which he described as feeling “mushy or at least a bit different than normal,” the pilot informed the controller he would initiate a go-around, but a tower controller warned, “Not enough runway,” a call the pilot later said caused confusion in the cockpit. Moments later, approaching the end of the runway, the pilot called for ejection.
Despite the controller’s warning regarding the lack of available runway, the now-crewless aircraft became airborne, climbing about 8,000 feet before stalling and crashing into San Diego Bay.
The Navy ultimately ruled out mechanical failure, attributing the mishap to human error combined with adverse weather conditions.
“The aircraft was unable to safely stop on the runway due to wet runway conditions and landing with a tailwind,” Navy Cmdr. Amelia Umayam, a spokesperson for Naval Air Forces, U.S. Pacific Fleet, told ABC 10, adding that investigators determined maximum braking techniques should have been used.
The Navy said approximately 85% of the aircraft was later recovered from the bay.
Matt Ryan
Leave a Reply
