Laredo Accident: When a Vibration Becomes a Warning
Preliminary findings from the Laredo Citation crash offer pilots a sobering lesson in recognizing unfamiliar anomalies, resisting bias, and declaring emergencies early.
[Credit: Markus Mainka | Shutterstock]
  • A NetJets Cessna Citation Latitude crash, which fatally injured two, was preceded by early flight anomalies (unusual vibrations, electrical/fuel system issues) that escalated after the crew continued the flight.
  • The crew initially downplayed the severity of early warnings, consulting flight operations who also underestimated the issue, possibly influenced by communication gaps and various aviation psychology biases.
  • The article emphasizes that pilots must prioritize "aviate, navigate, communicate," err on the side of caution with novel anomalies, and clearly communicate the urgency of an "emergency" to ATC, maintaining ultimate responsibility for flight safety.
First, my thoughts and prayers go out to the families and friends of the Laredo airplane crash victim. May his memory be a blessing as loved ones remember the legacy left behind.
On June 16, 2026, a Cessna Citation Latitude business jet came to rest on a highway in Laredo, Texas. The aircraft, operated by NetJets, was en route from Los Cabos, Mexico, to Austin, Texas.  Sadly the CEO of Austin’s Capital Factory, Joshua Baer, and his canine companion were fatally injured.
The NTSB recently released a preliminary report on the accident. There is mention of several mechanical nonconformances found during the preliminary investigation. The report notes damage found on the propulsion and electrical power systems.
Fuel and Electrical Issues
For the fuel system, “the right engine fuel pressure switch was found separated from the fuel tube assembly … the fuel tube assembly was fractured adjacent to the weld joint for the attachment tube leading to the fuel pressure switch,” and “multiple P-clamps on the fuel tube assembly were also found fractured.”
For the electrical power system, “the starter generator was missing multiple screws from the outer housing” and “the starter generator shaft was found bent.”
The NTSB also pointed out that the starter generator was barely three years old and just shy of 60 hours from its next 1,200-hour maintenance overhaul.
While one may be tempted to blame the incident on maintenance or manufacturing, the fact remains that the investigation is still underway. Until the final report is released, no speculation on definitive root cause should made. Furthermore, without a complete impact analysis, one cannot say whether the hardware issues mentioned in the NTSB’s preliminary report were due to the accident itself, or vice versa.
Nevertheless, regardless of what ultimately caused the aircraft to fail, there are initial findings from the Laredo crash that can be applied to pilots worldwide to enhance the safety of future flights.
Dealing with Novel Scenarios
The Cessna Citation Latitude pilots noticed an “unusual vibration” early in the flight. This “low frequency vibration” was accompanied by a “humming noise.” The crew noted that they had not experienced this before. It did not appear as if this was a common occurrence with memorized checklists.
Since the crew did not immediately know what to do to diagnose and fix the vibration, they called their flight operations (colloquially known as flight ops) duty manager on the telephone for advice.
To use a game show analogy, they “phoned a friend.”
The crew explained the situation to flight ops. During the call, the noise went away, and an aircraft alert annunciated. The fault was “BOTH ON ADC 1,” which indicates that both primary flight displays are sourcing air data parameters (e.g., altitude, airspeed, etc.) from Air Data Computer (ADC) #1 instead of their respective computers.
It is crucial to understand that flight ops support is not actively flying the aircraft or experiencing cockpit sensations. Support personnel quite literally know only what pilots communicate to them. Crew specifically told flight ops that the vibration sounded like “a fan is on.” Armed only with the information provided, flight ops mirrored what was told to them and suggested that the vibration may be coming from the avionics cooling fan.
To Declare or Not Declare (an Emergency)
Presumably convinced the vibration was benign, no emergency procedures were executed. Rather, a Quick Reference Handbook procedure was performed to clear the ADC message. While the full discussion between crew and flight ops is not yet available, the preliminary report notes that the outcome of the conversation was such that “the flight could safely proceed to its planned destination,” and that crew could later “write-up the vibration” after landing.
Nothing in the preliminary report indicates that the crew or flight ops thought they had an emergency on their hands.
As the aircraft continued its flight and approached the U.S.-Mexico border, a series of other fuel- and electrical-related faults annunciated. It was at this point that the Cessna Citation Latitude crew declared an emergency with Monterrey ATC in Mexico, who then handed them off to Houston ATC.
Per the preliminary report, the pilots “requested to divert” to Laredo Airport in Texas. It is not specified in the report and therefore not known whether the crew specifically used the term “emergency” with Houston ATC. The Cessna Citation Latitude crew requested a visual approach at Laredo International Airport on runway 36L with a five-mile final. However, since ATC deemed the business jet’s altitude too high, the aircraft was instead instructed to do a 14-mile loop to come back and land on runway 36L.
Human Factors and Aviation Psychology
While full timestamps are not yet available, details from the preliminary report point to initial warnings that were encountered early in the flight. After speaking with flight ops and clearing the ADC fault, the aircraft was able to continue the bulk of its leg.
More severe warnings (and eventual engine shutdown) did not occur until much later in the flight. Considering the original flight path and proximity to the United States when the emergency escalated, this suggests that the aircraft was able to safely fly for several hours after the first warning was cleared.
In aviation psychology, there is a something called the sunk cost fallacy. This is a common phenomenon whereby crew elect to continue a flight despite potentially unsafe conditions; this is typically due to various pressures such as time and money.
It must be highlighted that in the context of the Laredo crash, sunk cost fallacy does not assume that aviation personnel were fully aware of how unsafe their flight conditions were. If anything, current evidence points to the opposite.
There are also various biases in aviation psychology. Confirmation bias is the tendency to look for information that already supports a preexisting idea. Closely related is expectation bias, whereby one sees what they expect instead of what is actually evident. Then there is outcome bias, which judges a decision based on its outcome instead of the quality of the decision itself. As for automation bias, that places an undue over-reliance on automated systems over and above monitoring the aircraft itself. Lastly, authority bias influences individuals to defer to higher authorities; in this case, that may have been flight ops and ATC.
As an accident investigator with the perspective of an outsider looking in, it appears the Cessna Citation Latitude crew was not fully aware of how severe the aircraft’s condition was until it was too late. By explaining the vibration to flight ops in a rather benign fashion, all parties involved seemed to rule the incident a minor issue rather than a harbinger of deeper systemic issues.
Various aviation psychology biases may have led crew and flight ops to diagnose the vibration as a fan issue, despite there not being definitive proof of the vibration’s root cause. The crew appears to have deferred to flight ops, accepting their conclusion that there was no significant safety issue with the aircraft. Later, the crew also deferred to ATC when their original five-mile landing request was extended a whole nine extra miles.
Engineers Versus Pilots
As someone who has been on both sides of the cockpit window—both inside and outside—I understand the limitations that exist in each profession. Engineers who have never flown an aircraft may not understand what is going on in the flight deck. Meanwhile, pilots who have never designed aircraft may not be able to explain complex system architecture that goes beyond their training.
Furthermore, not every aircraft fault annunciated is labeled with text that makes it immediately obvious what the underlying aircraft issue is. Of course, warnings like “FUEL LEVEL LOW R” and “ELEC TRU FAIL R” that were later displayed to the crew clued the pilots in on the fact that something was seriously wrong. Unfortunately, however, by the time those faults came on, it was already too late. (For reference, TRU stands for Transformer Rectifier Unit and is a component that converts AC power to DC power in the event of a DC generator failure.)
The first “BOTH ON ADC 1” fault may have seemed harmless to pilots without an aeronautical systems engineering background. One cannot assume that the crew knew this fault could be indicative of an electrical issue. One also cannot assume that the crew understood the aircraft’s design well enough to know that the engine shaft cranks an accessory gearbox to allow the generator to supply electrical power, particularly in the heat of the moment. To assume even an exceptional flight crew is able to connect the dots that an ADC fault may be caused by an electrical issue that in turn could be caused by an engine or fuels issue is simply impractical.
Understanding Limitations
Even if one assumes the root cause of an issue is known, there must be an acknowledgment of limitations in what is known versus unknown. Just as I, as an accident investigator, can not claim to definitively know what caused an accident prior to the final investigation being finalized, no crew or support personnel can claim to definitively know what is causing an aircraft issue prior to final inspection on the ground.
Even if experts diagnose an issue as benign, pilots ought to operate with the understanding that those individuals only know what is being told to them, and that they are not inside the aircraft. To put it grimly, anyone outside of the aircraft giving advice does not have to live with the consequences of said advice in the same way those on board do. There may very well be instances where someone on the ground or even in the tower advises the crew to carry on when, in reality, the best action may very well be to execute an immediate emergency landing.
In an emergency, every minute counts. The Cessna Citation Latitude aircraft being advised to nearly triple its distance to a landing site while in an emergency situation is certainly noticeable. It is not known what specifically transpired between ATC in Mexico and ATC in Texas, specifically, whether or not Houston ATC knew the Cessna Citation crew needed to perform an immediate emergency landing as opposed to a less urgent diversion.
Until the final investigation report is released, it is not known whether the Cessna Citation Latitude could have safely performed an emergency landing with its originally requested five miles of clearance, or if the crew could have performed an alternate emergency landing.
Still, one can’t help but recall the infamous Flight 1549, commonly referred to as the Miracle on the Hudson. Captain Chesley “Sully” Sullenberger defied ATC guidance when he ditched his dual-engine failed aircraft on the Hudson River.
What Can Be Learned
So what does all this translate to for the average pilot? Quite a lot, in my humble opinion.
Whenever a pilot encounters a new issue they have never experienced before, there is naturally going to be initial shock. It is important to follow the rule of aviate, navigate, and communicate. Changing the order to aviate, communicate, and navigate can unintentionally jeopardize safety.
No matter the pressures from passengers or even the crew themselves, the pilot in command must always err on the side of caution. What may seem like a harmless anomaly or minor inconvenience could actually be a sign of a more dangerous condition. Lastly, when communicating with ATC in an emergency situation—especially multiple controllers across different locations and countries—the pilot in command must always repeat the urgency of the situation and be sure to stress the term, “emergency,” over again.
Even if 99% of the time turning back early may be unnecessary, it is worth it to be conservative, as one never knows when it will be their turn to be the 1%. The pilot in command is ultimately responsible for the safety of all on board (themselves included) and may sometimes have to make the executive decision to go against what others are telling them to do.
Teresa Konopka
Teresa Konopka is an aviation safety professional specializing in systems safety engineering for civilian, commercial and military unmanned aircraft. She has served as a mishap investigation engineer and holds a B.S. in Aeronautical Engineering from Rensselaer Polytechnic Institute and an M.S. in Aviation Safety from Embry-Riddle Aeronautical University, with experience at Boeing, General Atomics, and Northrop Grumman.
  1. As a former NJA pilot with loads of experience in the Citation Latitude, as well as an experienced accident investigator from the US Navy and a graduate of the Naval Aviation Safety School, I would argue against jumping to the conclusion the pilots were at partial fault for not heeding an unknown vibration / noise. It is true that these things are possible signs of a serious problem, but once in flight over Mexico, I cannot say that a declaration of an emergency and a landing at just about any airport in Mexico would have been the proper course of action.
    The aircraft system’s EICAS should have provided more timely awareness of the impending failures, as well as true separation of critical systems (I.e fuel and electrical.). Cessna / Textron has a long history of cobbling together systems from older approved designs (The Latitude shares many commonalities with the CE-680 Sovereign) that may not reflect a robust Part 25 design, although so approved. Often NJA will discover issues that no one else finds because the aircraft is operated 4-5 times more per year than a typical Part 91 firm.
    I would submit this tragedy could not have been prevented due to multiple design failures couple with a lack of thought put into the EICAS to alert the pilots of a major failure. Relying on ‘gut’ instincts and vibrations, sounds is a good technique for GA pilots flying 50 year old piston aircraft, but shouldn’t have any place in flying a modern jet equipped with the latested systems.
  2. My friend, a former Jaguar pilot with the Royal Air Force of Oman, was on a long-range mission with two large drop tanks. At the stage where he was at the point of no return he got a fire warning from the reheat zone. Some quick thinking deduced that he was in a sticky position. If he ditched the tanks he would definitely not have enough fuel to get back, but if he kept them his fuel consumption would mean he would be VERY tight on fuel. He kept the tanks and sneaked it in with no diversion fuel..
    The cause was a thrown turbine blade, which set up vibrations that happened to be at the resonant frequency of the reheat fuel delivery pipe, which promptly fractured causing the fire.
    This accident could well be caused by sympathetic vibrations!
  3. Teresa I thoroughly enjoyed reading your write up of this incident. Helped me understand a lot of stuff in your step-by-step, slow progression and explanations really helped my knowledge grow so appreciate the clear concise article.
    Thank you
  4. There are serious flaws in your analysis:
    1. Reportedly the pilots also talked to a maintenance person. That is far more than just talking to flight ops.
    2. The ultimate/higher authority is always the pilot in command…not ATC or flight ops.
    3. The plane likely crashed due to fuel starvation yet the preliminary report and your analysis do not discuss that. If the two fuel tanks are normally isolated, how did a “rupture” in the fuel system on the right side cause a complete loss of fuel?
    As for the right 270 degree turn that put them on a long final, the pilots probably made a fatal mistake with that. State “unable” and descend over the Laredo airport.
    I am not that concerned about the original problem. They sought input. There was probably no way to know that a generator was about to grenade itself or that a fuel system tube would fracture.
    What concerns me is that there is zero talk of what likely caused the crash…running out of fuel and secondly not descending over the airport.
  5. Avatar for Guy Guy says:
    I am not any kind of heavy metal flyer, but l do know and understand that a vibration that arrives via the shell of the aircraft is a whole ball of wax and a few orders of magnitude difference in energy level than a fan in the avionics. A simple walk of the plane should have told them all they needed to know.
    Also, I did a 737 SIM weekend with United just before 9/11. Preparation for that was an extensive review of the aircraft systems with a particular emphasis on what could go wrong and what signature alert profiles they would throw.
    If that level of detail is no longer expected of pilots, then this type of thing will happen more and more often. PIC means exactly that.
  6. I’m not commenting on this crew in particular, but knowledge of your aircraft systems to the greatest extent possible is a must. The author states “one can also not assume that the crew understood the aircraft’s design ‘well enough’ to know that the engine shaft cranks an accessory gearbox to allow the generator to supply electrical power”. While that may be a plausible observation, it bothers me. Again, not commenting on what this crew did or did not understand, but if you are flying this level of airplane and you don’t understand something like what accessories come off the engine and how they are powered, then you should not be flying that plane, nor should you be able to pass any credible ground school or checkride. Systems knowledge will at least give you a chance to connect the dots from what you see and feel, back to a potential root of the problem. Please note that I said “a”, not “the”, because you may not know for sure; be open to modifying your analysis. It does help to have a good EICAS design on your side, but it isn’t a substitute for raw knowledge. I flew a plane for years where ‘root’ messages, i.e. pertaining to the component related to the primary problem, were displayed at the top of the stack, with consequential messages following. Either way, give yourself a chance to deduce the potential ‘root’ cause of problems by spending time in the AOM when not flying. Flight display / ADC reversion to backup configuration, okay. Accompanied by electrical system abnormalities, okay, maybe not just a screen or ADC component failure. Accompanied by vibration, okay now something mechanical is happening, the generator?..Do we see engine core vibration? No? Okay, maybe isolated to the engine accessory section. How’s my fuel? Look at the tank totals. Wow, fuel imbalance is developing. Potential fuel leak. Okay, declare an emergency, get the airplane on the ground. Do I have enough fuel with a potential leak? I know my AOM fuel imbalance limit in pounds is X. How will the imbalance affect the way the airplane handles? Does it make sense to crossfeed, or will that just waste fuel we can’t spare? Single engine options. Copilot flies and talks to ATC after a plan is agreed upon. Captain handles checklists, briefs passengers, and advises ‘company’ if time allows. Captain probably takes flying duties back for approach and landing. Study your AOM. Then go through scenarios like this in your mind, at home or in the hotel to give yourself a fighting chance to enjoying a long career.
  7. I must be a little lucky. I’ve had a blower motor go up in smoke, 5 miles from an airport. Put it down, and called the owner of the aircraft to pick me up. Microphone switch break, close to another airport. Circled just outside their airspace, and they vector me in. Lost an alternator on a return trip, 5 miles back to home. Tachometer cable snapped just outside the quad cities approach control. Luckily there wasn’t an engine issue, and again, i made it back.
