GAO Flags Gaps in Drone Airspace Safety
Report says FAA must clarify roles, milestones for aircraft communication and avoidance.
FAA Wants Feedback on UAS Airport and Droneport Integration
[Credit: GAO]
  • A new GAO report highlights significant safety gaps in the integration of Beyond Visual Line of Sight (BVLOS) drones into national airspace, stating that the rapid increase in BVLOS operations is outpacing regulatory and technical development.
  • The report criticizes the lack of detailed planning for drones to consistently communicate with and avoid other aircraft, noting that current detect-and-avoid technologies are insufficient for large-scale integration.
  • Despite the FAA's long-term vision for an information-centric airspace, the path to achieving reliable two-way communication and coordinated operations for BVLOS drones remains undefined and lacks concrete implementation steps.
  • The GAO recommends that the FAA develop and implement specific plans, including defined roles and measurable technical milestones, to ensure safe drone integration, a recommendation supported by the Department of Transportation.
A new federal report from the Government Accountability Office (GAO) studied the present state of drone integration into the national airspace system and reported a number of safety gaps, even as beyond visual line of sight (BVLOS) drone flights are expected to rise substantially in the near future.
The FAA is working on proposed BVLOS rules and is engaged in relevant research, but the GAO’s report suggests that the rise of BVLOS operations is outpacing the development of an adequate regulatory framework. According to the report, no planning that presently exists deals directly enough with the specific actions, responsibilities or technical milestones that will be required in order for drones to communicate with and avoid other aircraft in a consistent and standardized way during routine operations.
The report points out some of the limitations inherent in today’s detect-and-avoid approaches. It notes that existing technologies rely heavily on systems that cannot support large-scale integration on their own. According to GAO, the FAA has articulated a long-term vision for an information-centric airspace in which aircraft share two-way position data electronically, but planning so far lacks the detail needed to guide implementation and adequate systems are not yet in place for this to be accomplished successfully yet.
The agency has proposed regulations requiring drones flying beyond visual line of sight to detect and avoid other aircraft, yet GAO said the path toward achieving reliable two-way communication and coordinated operations remains undefined. Defining solutions to this problem is one of the reasons why the FAA reopened its comment period for its proposed Part 108 BVLOS ruleset, although that period closes on Feb. 11.
GAO recommended the FAA develop and begin implementing concrete steps, including clearly defined federal and nonfederal roles and measurable technical milestones, to support safe integration as drone activity increases. The Department of Transportation agreed with the recommendation, the report said, as policymakers continue to examine how expanding commercial and public-safety drone use will fit into a national airspace system designed primarily around crewed aviation.
Matt Ryan
2 thoughts on “GAO Flags Gaps in Drone Airspace Safety”
  1. Since Drones are more navigable than fixed wing aircraft. One would surmise that drones should have an ADSB system to avoid all other types of aircraft.
    Drones shouldn’t be allowed to operate within close proximity to any airport.
  2. It is absolutely astounding that the FAA has allowed commercial drone operations but traffic management and conflict avoidance schemes and protocols are not even in the planning stage, so not even a timetable for when it will all come together?! Are they waiting to see if any operators come up with their own proprietary technology? That’ll work nicely, like Babbel.
Leave a Reply
