A380 Hits RJ At JFK (With Audio and Video)
  • An Air France A380's wing-tip collided with the tail of a stationary Comair CRJ 700 at Kennedy Airport.
  • The A380 was moving at approximately 20 mph, causing the CRJ to spin nearly 90 degrees, but no major injuries were reported.
  • The incident is under investigation, with a likely focus on the Comair jet's position and the directives that led it to be there.
Don’t see a video screen?
If that doesn’t work, click here to download the video directly.
All the usual agencies are now fully engaged in the investigation of the wing-tip-to-tail collision of an Air France A380 and a Comair CRJ 700 at Kennedy Airport in New York Monday evening. The likely focus of the investigation will be the position of the RJ and who decided it should be there. Judging by the departing A380’s brisk pace down the taxiway, the crew evidently didn’t anticipate any interference on the way to the runway. The Comair flight had just arrived from Boston and was stationary. What happened next is one of the reasons passengers are supposed to keep their seatbelts on until the ground crew person crosses his or her arms.
The A380 looked to be traveling at least 20 mph when the left wing tip hit the tail of the RJ. The impact spun the smaller jet nearly 90 degrees and rocked the plane from side to side. No major injuries were reported due to the collision. Photos show a torn up wing tip on the A380 but the RJ is likely in for a thorough inspection.
At right are a video of the incident (top) along with a clip that includes the audio exchange that followed (bottom).
