Can 94UL Replace 100LL? TCM Thinks So
  • Continental is actively researching and developing 94UL as a lead-free replacement for 100LL avgas, in response to anticipated EPA regulations.
  • 94UL is essentially unleaded 100LL and is expected to be compatible with many engines, including those certified for 80/87 octane and some higher-power, low-compression Continental engines.
  • High-compression ratio engines (e.g., 8.5:1) pose a challenge and may require modifications like timing tweaks, knock detection, or re-engining to operate on 94UL.
  • Continental is pursuing ASTM approval for 94UL, with an estimated three-year timeline, though one company (presumed to be Lycoming) remains skeptical of its universal drop-in capability.
Continental is moving forward with its research to pitch 94UL as a replacement for 100LL avgas, which the EPA seems serious about regulating out of existence. At the company’s Mobile, Alabama test center, TCM is running detonation tests of 94UL and on Wednesday, it gave visiting journalists a preview of the project. TCM’s Bill Brogdon told us on Tuesday that 94UL is essentially 100LL without the tetraethyl lead added as an octane enhancer. He says engines certified to operate of 80/87 octane-and that’s a lot of engines-will have no trouble making rated power with 95UL. Similarly, says Continental, even its higher power turbocharged large displacement, low-compression ratio engines can run the lower octane. The problem engines are higher compression variants that use 8.5 to 1 compression ratios. Brogdon told us these engines may tolerate a diet of 94UL by tweaking the timing or developing affordable knock detection and variable timing. Another option, he says, is reduce compression ratio but increase displacement-re-engining with a IO-550 to replace an IO-520, for instance. Whether the owners of aircraft with these engines will nibble on that remains to be seen.
In the meantime, Continental is in a consortium pushing forward with eventual ASTM approval for 94UL, at least for Continental engines. According to sources outside of Continental, only one company is skeptical of 94UL as a drop-in replacement for 100LL – and although no one is naming names, we take that to be Lycoming. Timeline? About two years of further testing, says Brogdon, then another year or so for ASTM approval.
