The FAA is also proposing the adoption of a new AD for certain Dassault Model Falcon 2000 and 900EX and Dassault Model Mystere-Falcon 900 series airplanes. This proposal would require measuring the paint thickness on the upper and lower surfaces of the left and right sides of the horizontal stabilizer, performing corrective actions if necessary, and installing maintenance caution placards on the upper surface of the left and right sides of the horizontal stabilizer. The FAA claims this action is necessary to prevent structural damage to the horizontal stabilizer after a direct lightning strike, which could result in reduced controllability of the airplane. This action is intended to address the identified unsafe condition. All comments must be received by Dec. 15, 2003.
Dassault Falcon 2000 and 900EX
- The FAA is proposing a new Airworthiness Directive (AD) for certain Dassault Model Falcon 2000, 900EX, and Mystere-Falcon 900 series airplanes.
- This AD would require measuring paint thickness on the horizontal stabilizer, performing necessary corrective actions, and installing maintenance caution placards.
- The action is deemed necessary to prevent structural damage to the horizontal stabilizer from direct lightning strikes, which could lead to reduced aircraft controllability.
