FAA Certification Of New “Commuter” Zeppelin Under Way
  • The FAA is developing new, extensive design criteria for the modern Zeppelin LZ N07, a smaller airship built by the original German company, intended for multi-mission use with 12 passengers and 2 crew.
  • This certification process is complex because Germany classified the airship in a commuter category, requiring the FAA to rewrite its existing bilateral rigid airship requirements.
  • The development of these detailed technical and performance specifications has been ongoing for six years since Germany's initial request in 2001.
  • A public comment period is open until June 4 for input on the proposed design criteria.
FAA Certification Of New “Commuter” Zeppelin Under WayThe FAA has issued proposed design criteria for a modern and much smaller incarnation of the famous Zeppelin airship. Built by the same German company that brought us the Hindenburg, among others, in the early part of the 20th century, Zeppelin LZ N07 builds on the hard-won knowledge about safe operation of the aircraft. The newest version first flew in 1997 and is designed as a multi-mission aircraft that can carry up to 12 passengers and two crew. The U.S. and Germany already had bilateral certification requirements for rigid airships, but because Germany elected to certify this new airship in a commuter category, the FAA apparently has to rewrite its requirements. The result is dozens of pages of technical and performance specifications that cover everything from the engine-out performance to the quality of water used as ballast (has to be potable water if its to be released anywhere but at a sewage treatment plant, which might be difficult to flight plan). Germany first made the request to have the aircraft recognized by the FAA in 2001 and its taken six years to get it all on paper. In case you have an opinion on the way these things should be built, a comment period lasts until June 4.
