FAA Proposes Part 25 Icing Amendments
  • The FAA has proposed new icing certification requirements for Part 25 (transport category) aircraft, particularly those weighing less than 60,000 pounds, to enhance safety in severe icing conditions.
  • The proposed rule specifically addresses ice caused by supercooled large droplets (SLD) and will also require turbine engines to handle icing conditions that have led to uncommanded shutdowns.
  • This Notice of Proposed Rulemaking (NPRM) is a response to a 1994 icing-related crash and is estimated to incur an annual industry-wide compliance cost of $71 million.
The FAA has issued a Notice of Proposed Rulemaking (big PDF) that would impose extra icing certification requirements on Part 25 (transport category) aircraft that weigh less than 60,000 pounds and would also amend rules for larger aircraft. The rule has been in the making since the 1994 icing-related crash of an ATR 72 in Roselawn, Ind. For smaller aircraft, the rule focuses particularly on ice caused by supercooled large droplets, which can coat surfaces beyond the normal ice protection systems on existing aircraft. “These regulations will help ensure future aircraft can operate safely in some of the toughest icing conditions,” FAA Administrator Randy Babbitt said in statement.
The NPRM will also affect engine certification. Turbine engines will have to be able to handle icing conditions that have been the cause of uncommanded shutdowns. The agency estimates the annual industry-wide cost of compliance will be $71 million. The comment period on the NPRM ends Aug. 30.
