February 406 MHz ELT Conversion May Put Focus On 121.5
  • As of February 1, 2009, satellites ceased monitoring 121.5 MHz emergency locator beacons (ELTs), meaning users of this older technology will rely solely on ground stations and overflying aircraft for detection.
  • While upgrading to 406 MHz ELTs is optional in the U.S., safety-conscious operators are advised to adopt this technology for enhanced search and rescue capabilities.
  • 406 MHz ELTs transmit a stronger, more accurate digital signal and require registration, allowing rescuers to contact owners directly and prevent unnecessary search operations.
  • International regulations for 406 MHz ELTs vary, with countries like Canada planning a transition period, and Mexico allowing 121.5 MHz for U.S. aircraft until June 2009.
Feb. 1, 2009, marks the end of satellites’ ability to notice your 121.5 MHz-specific emergency locator beacon (ELT), but — in the U.S. — changing your equipment to the satellite-monitored 406 MHz is optional. After January, voluntary use of 121.5 MHz equipment, only, means that those operators accept they will be depending on ground stations listening on 121.5 and pilots of overflying aircraft — that means you — to find them. Search and rescue will still use whatever methods are available to help them find you, and in the case of your 121.5 MHz ELT, that may provide some measure of comfort. But the truly safety-conscious may now consider adding the layer of 406 MHz technology either through an ELT upgrade or the many personal locator beacons now available. As for Canada and Mexico: Canada has not yet required that aircraft flying in its airspace be equipped with 406 MHz ELTs. The country is planning a two-year conversion period and has yet to set rules for the transition, according to AOPA. Flying to the Bahamas will not require 406 MHz equipment, but that may change after January of 2011. Mexico will allow U.S. aircraft using 121.5 MHz ELTs to fly within the country until the end of June 2009, unless they reach a mandatory ELT battery replacement date first. The Cospas-Sarsat System has been and will continue monitoring signals transmitted on 406 MHz.
The 5-watt digital signal transmitted by 406 MHz equipment is stronger and more accurate than 121.5 and must be registered to a specific owner. Registration means that rescuers, once alerted by a 406 MHz signal, can call the owner first, before launching a search just to find an aircraft that is simply being transported on a truck, for example. For more information, see Sarsat.
