…Higher Costs, More Hassles…
  • Proposed new regulations are expected to significantly increase operational costs for air tour operators, including both Part 91 and larger companies.
  • Specific rules require passengers to wear inflatable flight vests for all over-water flights and sightseeing helicopters to be equipped with expensive emergency floats.
  • Operators criticize these regulations for their high added expenses and operational complexities, regardless of factors like the size of the water body or flight altitude.
Although it can be argued that Part 91 operators will be the hardest hit, larger companies are also counting up the costs. Jim Cruson, president of Air Vegas, one of the biggest air tour companies in the country, says some of the proposed regulations will hit his firm squarely in the bottom line. For instance, his company’s fleet of 10 Beech 99s routinely flies over Lake Mead and the new rules would require all passengers to be wearing an inflatable flight vest for the duration of each flight. “It’s ridiculous,” said Cruson. Besides the added expense, there is also the time lost showing people how to wear and operate the vests. The life-vest rule would apply regardless of the size of the body of water or altitude and gliding-distance criteria. The water overflight rules will cost helicopter operators even more, however. The agency proposes that helicopters used for sightseeing be equipped with emergency floats that will keep them upright in an emergency ditching. The agency’s own estimates peg the cost for each helicopter at between $19,000 and $39,000.
